Can a harness be used with 5th gen seats?
Old Sep 17, 2002 | 12:01 PM
bw54867's Avatar
Default Can a harness be used with 5th gen seats?
I am not familiar with harness mount points?Is it possible?
Old Sep 17, 2002 | 12:18 PM
Furry
Guest
Posts: n/a
Default Re: Can a harness be used with 5th gen seats? (bw54867)
using anything other than the stock seat belts w/o a cage or at least a roll bar is very dangerous, especially with the stock seats. if you roll the car and you are straped in with a 5pt harness you wont move and the top of the car will come crashing down on you. in a rear impact the seat back could brake b/c of the extra tension on the back of the seat. its not a pretty site
Old Sep 17, 2002 | 12:31 PM
TimeRacer's Avatar
Default Re: Can a harness be used with 5th gen seats? (Furry)
It's possible to put a harness in a Gen5 but yes do not use it for everyday driving. Though I think what fury is talking about is more a frontal crash and having the belts at greater than a 45 degree angle. This (if enough force) causes spinal compression where your momentum is deflected down instead of forward and essentially putting all the forward movement energy into your spine.
Old Sep 17, 2002 | 01:14 PM
Accord94DX's Avatar
Default Re: Can a harness be used with 5th gen seats? (TimeRacer)
both of you guys nailed it.
trevorjohn88ef
Jul 19, 2008 04:09 PM
integraboosted
Jun 21, 2005 12:03 PM
Race Egr
May 8, 2005 05:09 PM
eymnewdc4
Mar 10, 2005 09:37 AM
Erik_Pb_Foot
May 29, 2002 08:58 AM
