WTF does the Hondata intake manifold do for B series?
Old Sep 17, 2002 | 11:58 AM
URAS-J's Project D1's Avatar
Default WTF does the Hondata intake manifold do for B series?
Whats so special about it,and what does it do,same thing as OEM honda one or what? is it for performance gains or what.Please explain to me?
i have never seen one,just seen people listing it in there mods.Does it do the same as the ventuli plate or something that Spoon offers.
thanks in advance
Cheers
Aaron
Old Sep 17, 2002 | 12:04 PM
Spade's Avatar
Default Re: WTF does the Hondata intake manifold do for B series? (SiR-Technikz)
It is a thermal barrier between the head and the intake manifold to prevent heat soak.
Old Sep 17, 2002 | 12:59 PM
Default Re: WTF does the Hondata intake manifold do for B series? (Spade)
proven to work?
Old Sep 17, 2002 | 02:42 PM
Eee Pee's Avatar
http://hondata.com/heatshield.html
Try here.
Old Sep 17, 2002 | 02:49 PM
Default Re: WTF does the Hondata intake manifold do for B series? (E Prepared)
thx guys for zee help
maybe when i port out the intkae manifold or soemthing i ll get one while im at it
Thx again
Aaron
Old Sep 17, 2002 | 03:03 PM
shawnhayes's Avatar
It also blocks off manifold heating/cooling passages. This is not a good idea if you live in very cold climates and daily drive your ride. This is a horsepower modification, not a drivability or a durability one. Dissipation of some of the block heat into the manifold helps cool the block, and decreases some of the temperature differences that the manifold sees from throttle body to block.
Honda designed the manifold and throttle body to be heated by coolant. Modify it at your own risk. You may gain horsepower, and you may not lose anything. But, nobody knows FOR SURE why Honda designed it this way, but I suspect they meant it to do something useful.
Shawn
[Modified by shawnhayes, 7:03 PM 9/17/2002]
advan414
Oct 1, 2014 08:36 PM
swlabhot
Sep 21, 2005 03:15 PM
zattypleat
Apr 21, 2005 03:51 PM
NXLude
Mar 12, 2004 07:08 AM
loctoutnicca
Mar 9, 2004 09:33 PM
