Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
my list of items for a full tune up. anything else am i missing?
Old Aug 20, 2010 | 07:42 AM
949's Avatar
949
Default my list of items for a full tune up. anything else am i missing?
i wanted to replace everything that maybe or will be going out because wear and tear. i have time now and wanted to just place everything. is there anything else i could do?
130k mi tune up
no tune up has ever been performed.
only oil changes
-a/c belt
-alternator belt
-power steering belt
-timing belt
-timing belt tensioner
-spark plugs
-valve adjustment
-valve cover gasket
-water pump
-engine oil
-coolant
-crank seal
-cam seal
-cam belt
-cam tensioner pulley
-cam tension spring
-upper radiator hose
-lower radiator hose
-transmission oil
post edit add:
-oil filter
-air filter
-thermostat
-radiator fan switch
-evap filter
-spark plug tube seals
Old Aug 20, 2010 | 08:22 AM
EM2abe's Avatar
Default Re: my list of items for a full tune up. anything else am i missing?
oil filter
Do you plan on doing brakes and rotors?
Old Aug 20, 2010 | 08:57 AM
949's Avatar
949
Originally Posted by EM2abe
oil filter
no, only engine work this time.
thanks.
Old Aug 20, 2010 | 09:00 AM
EM2abe's Avatar
Well, if you're planning on doing the radiator hoses then you might as well do the thermostat and radiator fan switch as well. They are right there by the upper.
Old Aug 20, 2010 | 09:51 AM
lazlong's Avatar
evap filter
Old Aug 20, 2010 | 10:12 AM
949's Avatar
949
Originally Posted by lazlong
evap filter
im actually not familiar with this item.
what does it do?
Old Aug 20, 2010 | 10:21 AM
honda.lioness's Avatar
The a/c belt and alternator belt are one-in-the-same.
Add spark plug tube seals.
Old Aug 20, 2010 | 10:26 PM
suds1485's Avatar
might as well do the oil pump instead of the crank oil seal
Old Aug 21, 2010 | 05:58 PM
lazlong's Avatar
what does it do?
Controls vapors in the gas tank and fuel system. It's under the rear of the car on the driver's side.
Here's some pics:
Old Aug 22, 2010 | 11:18 PM
DJ4Jesus77's Avatar
Just out of habit i would check your power steering fluid and brake fluid. Never hurts to check. and i think sparkplug seals normally come with a valve cover set...lol or atleast mine did. Good luck to you!
Old Aug 22, 2010 | 11:37 PM
It Wasn't Me's Avatar
It's a bit late for this, but, from the FAQs...
Maintenance schedules: Link
As DJ4Jesus77 mentioned, flush the power steering and brakes. Especially since it's never been done.
Old Aug 23, 2010 | 03:42 PM
cman7's Avatar
Fuel filter, PCV valve.
A cabin air filter wouldn't hurt, but that's not important to your engine. Mine was filled to the brim with corn, dust, pollen, and practically everything else. I'm willing to bet it had never been replaced in the duration of the car's life.
Old Aug 23, 2010 | 04:07 PM
kozanatos's Avatar
I hear that too. it is one set, you put them on at the same time...
Check this one out.. Oil pan gasket Just check it, i doubt its leaking, BUT if you are going all out its cheap
<$15 for my engine
Old Aug 23, 2010 | 04:28 PM
Originally Posted by kozanatos
it is one set
Nope. See bkhondaparts.com. The spark plug tube seals and valve cover gasket are two different part #s, just like the older Hondas.
Lotta stuff being added that I would let be, e.g. the oil pump, PS fluid, the oil pan gasket (unless leaking), the radiator fan switch, and the fuel filter (unless it fails the test in the manual). The fuel filter is in the back of the car and not something that goes hand-in-hand with the other engine work insofar as labor is concerned.
A single belt is used to drive both the a/c compressor and the alternator. They should not be listed as two separate belts, but I suppose the OP has not looked at the drawings or engine yet.
Old Aug 23, 2010 | 04:46 PM
kozanatos's Avatar
Originally Posted by honda.lioness
Nope. See bkhondaparts.com. The spark plug tube seals and valve cover gasket are two different part #s, just like the older Hondas..
eek! Sorry for spreading misinformation. I was under the impression that it was always a set. I guess its just hand in hand > your going to replace your Valve cover gasket, your also replacing the sparkie gaskets
Everyone, I sorry.
chappys4life
Sep 17, 2018 05:00 PM
alpha honda fan
Apr 30, 2013 02:18 PM
AllMotorDA9
Oct 2, 2008 08:35 PM
Yolandita
Apr 27, 2006 04:06 AM
nek0
Sep 26, 2002 10:46 PM
