1990 Civic Hatch SI, White
Old Aug 19, 2010 | 06:16 PM
jdmef253's Avatar
Default 1990 Civic Hatch SI, White
90 Honda Civic SI Hatchback
I am the second owner of this car. The previous owner towed it behind a motor home for the first year of its life. That is Where a large amount of the miles came from. The original owner also was talked into having a single ZC swap put in last September, due to the original motor being overheated.
Body is 8.5/10
a scuff in the front bumper and rear bumper is the only blemish.
Interior is 8.5/10
Normal bolster wear is the only interior blemish.
Has a Panasonic cd player and speakers.
Has factory option rear speaker pods as well.
Modifications
Ground Control Coil overs, tokico blue struts, and custom extended top hats. all put on 3 months ago. rides really well.
Gsr rear disk brakes.
stainless steel brake lines in all 4 corners
Suspension techniques front and rear sway bars with poly bushings.
Short ram air intake.
2 1/4 custom side exit exhaust, comes out right before the passenger rear wheel.
Timing belt
Water pump
Valve Cover gasket
distributor
plugs
wires
have all been replaced in the last 3000 miles
consistently gets 34mpg every fill up
odometer holds 248k miles, but keep in mind the motor has been swaped and it was towed behind a motor home for a year.
these are starting to get rare, and SI, and it is factory oem white.
Brand new toyo tires
only trade that i am interested in a a full size, 1992 or newer, four wheel drive pickup.
Clean title
$2800
Located in Bremerton
call, text, or email, it all gos to my phone. 360-649-5486
Old Aug 19, 2010 | 11:10 PM
jdm_dc_fan's Avatar
From: "That one guy with that one car" Kennewick WA
Default Re: 1990 Civic Hatch SI, White
pm'ed you.
Old Aug 20, 2010 | 10:28 AM
lostinmiself's Avatar
pmed ya
Old Aug 20, 2010 | 10:35 AM
SLowDB's Avatar
That hatch is sexy, bump for you!
::MUGEN::INTEGRA::RSi
Jun 17, 2010 01:23 PM
6speedDC2
Dec 19, 2009 10:57 PM
vaskater
Sep 26, 2005 04:09 PM
