Possible check engine light because of vss?
Old Aug 19, 2010 | 06:14 PM
924drb20's Avatar
Default Possible check engine light because of vss?
im running into a strange issue and need some thoughts on this, recently my CEL light came on after a few minutes of driving, along with my spedo not working and my odometer not counting miles....Now when i turn the car off and back on the light goes away, then comes back within 5mins...and it does this every time... Could that light be because of my vss gone bad and not realising it until i drive for a few minutes? Thanks
Old Aug 19, 2010 | 07:52 PM
98civdx's Avatar
Master Detailer
Default Re: Possible check engine light because of vss?
Did you pull the code?
You said your speedo doesn't work, a bad vss would throw a cel
Old Aug 19, 2010 | 07:59 PM
Former User's Avatar
Read through the CEL sticky:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-pull-cel-d4-srs-abs-codes-code-lists-1901557/
Rupinder Summan
Jul 10, 2014 02:47 PM
8_UR_AWD
Honda Civic (2001 - 2005)
13
Mar 8, 2009 06:19 PM
SiTR
Feb 14, 2008 04:19 PM
Nikoli
May 3, 2004 11:59 AM
Voom
May 13, 2003 03:53 PM
