Honda Recall!!!!!
Old Sep 17, 2002 | 11:16 AM
zeroracerh's Avatar
Default Honda Recall!!!!!
well i got a letter in the mail the other day bout my car being recalled for a defect relating to motor vehicle safety exists in the ignition switch on certain 98-00 civics.
they said its Electrical contacts in the ingnition switch can wear prematurely due to high electrical current passing through the switch.worn out ignition contacts could cause the engine to stall with out warning.(for example, hard to start,stalls immediately after starting,ect.) may indicate that igition switch is failing. my car started doing all this when i frist got it then it hasnt done it since so, has anyone else had this problem? If so im sure ull either get a letter or u should call Honda.
[Modified by zeroracerh, 8:41 PM 9/17/2002]
[Modified by zeroracerh, 9:16 PM 9/17/2002]
Old Sep 17, 2002 | 12:46 PM
phillycx's Avatar
Default Re: Honda Recall!!!!! (zeroracerh)
Thanks for the heads up! My car has been acting up lately. Nothing major, but when at idle the engine feels much rougher than usual. (before it was so quiet i couldn't tell if the car was on.) I changed the air filter because it was dirty and this helped a little, but the car still idles rough. It may be due to the recall. I'm calling tomorrow. Thanks again.
Old Sep 17, 2002 | 01:07 PM
zeroracerh's Avatar
Default Re: Honda Recall!!!!! (phillydx)
yeah no prob! if theres anything i can do just im me and ill tell u what they told me.
Old Sep 17, 2002 | 01:27 PM
civic337's Avatar
just to let everyone know, when you go to get it fixed, make sure you bring the letter, because sometimes they wont do the work without it. at least they won't at my dealership.
Old Sep 17, 2002 | 02:44 PM
oldskool_rex's Avatar
Default Re: Honda Recall!!!!! (civic337)
you probably are not going to have any problems with getting a hard time. The Ignition switch recall applies to all Hondas, from 97-99. Just visit your local dealer. we just got the kits in stock this week.
Old Sep 17, 2002 | 02:49 PM
EddieHatchBlack's Avatar
Default Re: Honda Recall!!!!! (oldskool_rex)
hey guys this topic has already been covered. it doesn't apply to ALL honda 97-99, just certain ones. go register at http://www.ahm-ownerlink.com/ and u can see if your car needs to be fixed. my 97 didn't need a fix, my bro's 98 did. he hasn't recieved his letter yet, but he needs one and when we went to the dealer, they wouldn't do it without the letter.
Eddie
read this lazy guys https://honda-tech.com/zerothread?id=245139
Old Sep 17, 2002 | 02:53 PM
shawnhayes's Avatar
Check the Honda owners site before getting excited. Plug in your VIN, and it will tell you if this recall applies to you. Apparently Honda got a batch of badly designed ignition switches that went into many Hondas between 97-2001. It didn't go into them ALL, and you may not need a replacement. When this defect happens, it is quite obvious, and is not subtle. Rough idling will not be a symptom. Either it won't start, or it won't run, or it will stall and not restart. Check the VIN and get a replacement if you need it.
Shawn
Old Sep 17, 2002 | 03:05 PM
Default Re: Honda Recall!!!!! (shawnhayes)
if you have a 96-97 car, look for the emissions recall also. If you are eligable for this you get a free oil change, as well as a cap, rotor, plug wires and spark plugs!
honda genome
Mar 14, 2007 05:37 PM
honda genome
Mar 14, 2007 05:00 PM
anothervictum
Jun 3, 2004 05:42 AM
anothervictum
May 31, 2004 06:22 AM
Joe
May 28, 2002 08:15 PM
