How to get abs codes on 2004 accord?
ok well my moms abs light came on yesterday in her 04 accord lx and i wanted to know if there is anyway i can retrieve the code without a scan tool, like jumping a connector. if anyone knows can you please let me know, wanna get it fixed thanks
Any competent import shop should be able to read those codes. You could always try a battery reset by disconnecting the negative cable of the battery and waiting 3 minutes then reconnecting,start the car with loads off let idle ten minutes, reset radio codes, auto down/up and if equipped moonroof control unit. If light returns especially instantly then there maybe a circuit problem, if light returns as soon as you start moving then there may be a sensor problem, if light does not return then maybe it was a fluke deal. Checking the condition of your battery and charging system is very basic but necessary in dealing with any modern vehicles. If the battery is marginal and the starter pull is down to 9 volts while the ABS unit is requring its own power and there is a ABS UNit code. Super common with SRS unit failure codes from 94-97 Accords ie 8-5. I have watched good honda techs get that *** handed to them by batteries.
timyap
Oct 27, 2005 12:36 PM
