TONS of stuff, mirrors, headlights, turbo, MSD ignition, dizzy, hondata...PIX
TONS OF STUFF...
sorry for the crappy pix
not photographed items
stock EM1 mounts with inserts $75
1000cc RC injectors $250
Tial BOV $200
Tial 44mm WG $150 (scratched up, but works perfect)
FMIC 3" x 8.5" x 30" $175
GSR trans $400 pick up/local meet ONLY
Exedy Hypersingle clutch $550 (less than 2k miles)
slowmotion motorsports topmount mani $300
3" downpipe $100
no i will NOT part out body panels, or interior...they will go with the person who buys the shell complete.
PLEASE DONT CALL ME, if i dont recognize the number i won't answer. I'm usually working, and i CAN NOT TAKE CALLS AT WORK! if you need to get ahold of me the FASTEST AND EASIEST WAY IS THROUGH TEXT! #317-408-5206
99-00 civic SI steering wheel w/airbag and sensors $200 obo also have pass.side bag w/cover
99-00 civic NOT SI headlamps slight scratches $40
MSD 6462 6 series ignition box w/boost timing $200 obo
MSD blaster coil and ignition wires attached to B series Diz $200 obo
b16 IM w/sensors and fuel rail/regulator $125
Tial BOV $200
3" downpipe $100
PLEASE text me with questions or offers, or PM me...like it says, i WILL NOT answer phone calls...
don't forget I also have the ULTIMATE MONSTER MOTOR BUILD for sale also $5k FIRM
Darton MID sleeved B16B block @ 84mm w/ copper o-rings
ERL 5-main girdle w/ arp studs
Scat 95mm Crank
Crower billet rods
CP 9.7:1 pistons
Custom Cometic MLS headgasket
1/2" ARP head studs w/ custom dowel pins
b16 head ported and polished, combustion chanmbers de-schrouded to 84mm
manley inconel exhaust valves
manley stainless steel intake valves
supertech dual coil springs
supertech titanium retainers
Comp stage 4 turbo grind cams
NEW OEM PARTS:
oil pan 10an return bung tig welded to pan
oil pickup
oil pump
water pump
timing belt
tensioner
tensioner spring
tensioner bolt
H22 LMAs
camshaft seals
front and rear main seals
sidecover
sidecover gasket
valve cover gasket
oil pump pickup gasket
oil pump o-ring
main and rod bearings
thrust washers
cam gear keyways and bolts
oil pump bolts
water pump bolts
BRAND NEW PORT MATCHED EDELBROCK IM and IM GASKET go with motor
Scat 95mm Crank
Crower billet rods
CP 9.7:1 pistons
NEW OEM PARTS:
oil pickup
oil pump
water pump
timing belt
tensioner
tensioner spring
tensioner bolt
H22 LMAs
camshaft seals
sidecover
sidecover gasket
valve cover gasket
oil pump o-ring
thrust washers
oil pump bolts
water pump bolts
and the GSR trans sitting on the floor too $400 pick up/local meet only OBO
UPDATED LIST AND PRICING
sold mounts, GT35R, and Hondata allready...parts are moving QUICK! so get on it.
