95 Civic sedan wont start
My bro just baught a 95 civic and it wont start. Pulled a #1, no spark, clean out cap&rotor. It will crank over but it wont start, my rpm guage will not even bounce. Im not familar with this car, it has no coil, so am abit confuse knowing that I maybe looking at an electrical issue. Car has been part for three months.
Gratz!
laloquera
Gratz!
laloquera
Didnt notice the sound. When I pulled the #1 plug, I noticed it was dried and did not even smell like gas. Thanks for the coil/distribiture skematic, never seen this set up before. How do you test it, do crack open the disssy?
laloquera
laloquera
Well, My gaspump made noise so Im guessing Its working. I pulled the #1 plyg to double check, dry and no gas smell. Pulled out main relay, intact tabs, and shinny. So Im working my way towards the dizzy, pulled it off and notice the roter did not rotate. Im thinking timing belt, so I pulled the iol cap and saw that the cam did not move either. Im I Anyone?
laloquera
laloquera
If the cam isn't turning theres something wrong, either the timing belt is broken or the camshaft snapped. Pull the valve cover and upper timing cover to see whats going on.
What up! Didnt want leave u guys hangin on this one. It was timing belt, put a new one on and the car was sold within 24 hour. Flip it from $600 to $2,300.00.
95civicVic
Nov 28, 2013 07:08 AM
