NV KENNYbuiltEG6...scammer
bout his 800hp delsol...blew the motor already...tore it apart and it was a stock sleeve motor with jst some pistons and rods...dude is a bullshiter...dnt trust him or buy anything frm him...was told it was a aebs sleeved block and it had a portflow head...the head was a jg head an stock block...more than likley hooked one of his homies up with his fully built motor...no god dam way he made 802 hp on 81.5 on a 40r...like the dyno sheet said
And this is why you dont buy "800 whp" cars, unless you have a shop totally tear the car apart and put it back together.
And he has every single receipt from purchasing the item new and for installation.
But the fact that he falsely advertised something makes it so that you have a case against him.
I just really hope you didnt sign any "as is" or "off road use only" contracts cuz then ur ****ed.
Either way, thats a total scum bag move by his part, and in my opinion should have his ********* removed with a butter knife and have his mother be forced to eat them in front of him.
Thats how we deal with scammers in mexico, sadly here in america things are a lil different.
Hope you picked up the car at his house.
And atleast know where he lives.
Keep a cool head, and let authorities take care of it.
they told basically aint **** we can do...we made the deal and dat bout it...tryin to atleast get my quad back to recover some of da loses to build another motor...trusted the dude and we knw that churchs had tuned it...and reciepts are hard sometimes...look at how many of us buy stuff frm eachother on here...when we picked it up the axle had ****ed up so we really drive it dat much...fixed da axle and first pass on da streets it blew...seem honest and we knw where he lives...so we wrnt really worried
I will tell you what I know....
that motor used to be Jesse's and when jesse sold his 98 coupe to walter the engine/turbo was put into a hatch for victor and I "think" fernie or one of his boys bought the civic shell, that engine had a JG sleeved block and a head done up by me. turbo was a gt40r on a one fab manifold. last I had heard was the guy that got the car cracked or broke a sleeve on the JG block and that was that. guess he slapped all the stuff in a stock block and sold it, the JG block had some grinding done to it on the oil pan rail in the front for a prototype header the car ran when it was N/A. also the engine had crower rods and cp 82mm pistons (I know the piston because they where my old ones before I went 84mm) and a type r crank. Walter said you guys where trying to find info on the block that was in the car when victor sold it so I am trying my best to give every detail I remember.
David
PS: was the axle a dss stage 5 and messed up on the pass side outter spline? because when jesse had the setup in his coupe we ran a spool which made the axle pop out the splines on that side in hard turns.
David
^Nice info man, I feel ya dude, but you got it worse than me... I got ripped on a "fully built low compression single cam," luckily dude squared it up with me...
more info....
engine had a M21 Rocket Motorsports intake cam and stock GSR exhaust cam, also had supertech flat face nitrate coated ss valves and Rocket Motorsports springs and retainers, and if I am correct it had a blue valve cover with dual -8an fittings welded in and a custom catch can with braided lines. also it had a competition clutch twin disk and 1600cc injectors.
ok lets get this straigt my friend is posting for me i am the new owner of the delsol
kenny told me jessi from hybrid sold this motor to him it has 84 mm pistons aebs sleeve crower rods etc
it has has toda b cams and toda cam gears the gears are ****ed upalso on the gear
its not right i got this now and its blown
and
kenny changed his phone number because he sade he was scared from his life
becasue he said he is getting phone calls saying that u ****ed the wrong person
i did not do that by the way
kenny sent me pictures of the block before the head was on it
HE NOW TELLS ME HE JESSI FORM HYBIRD SEND THEM THIS PIC
is this true jessi ?
this is the picture of what kenny sent me
this is now the motor
and
the very bottom pic is of the JG block, look how close the steel sleeves are together and the block guard JG uses.
and I know thats the setup, I made the intercooler pipping and the fittings on the valve cover are welded from the inside (bolt in baffle) and the turbo mani that made it a bitch to run the hall sensor bracket (car was on aem with rsx coils). also the type r TB and it still has the blue 44mm wastegate and 4 inch downpipe which I made aswell.
and that motor was in jesse's 98 coupe when it was sold to walter and victor, walter and victor put the setup in a hatch and soon after victor sold the hatch, never seen the top pic of the closed deck block, and me nor none of my guys ever wear gloves, lol.. when jesse sold his car it was in full running shape minus the radiator which he was borrowing from me and I know walter and victor had it tuned at churches in the hatch back so the rest I can not honestly answer.
But I will say this, I owned Hybrid Performance and tuning in Bakersfield Ca, which we closed shop in 05, the 98 coupe was sold in 08.
i hate to say it man. but your best bet is just to re build everything you need to the way you want. and take this as a lesson not to buy cars this extreme without knowing the owner personally or having your hands in the build. looks like a sick sol either way...... good luck with everything btw
and if kenny does chime in and give me a call since his number is changed i will let u guys know and if he fixes the problem
i will make sure eveybody on honda-tech knows kenny is a good guy if not then oh well
in the mean time i am stressing again fixing this car building a new motor gonna cost me around 3 to 4 thousands just for this to be the right way
to replace these parts
How much did you pay for this thing? Prolly the same amount it would have taken to build your own...It sucks that your getting screwed on this (good luck with civil court, a civil judgement means nothing). Sounds like you have enough good parts to sell and start over...800hp cars are such a waste of money to BUY from others...Doesn't matter who it's from you risk the chance of it breaking...If you've had experience with them you would have known to tear it down and look before boosting...I hope all goes well for you but don't expect much...
Usually if you buy a used car it is purchased "as is" and no matter what happens after you buy it you're out of luck/screwed. However, if you have the posts or emails that prove that the person selling the car said all these parts were indeed in the car you do have a case. If they deliberately misled you(which you have to prove) you can win a civil case against him. Basically they are violating the contract because they lied about the car initially. You have to document everything, take a **** load of pics, and have a certified "shop" write you estimates and testify that the parts that were in the car were not what the seller represented them as.
You are correct with the fact that he does have a case...but if the seller decides he will not comply, there's not much that can be done...the judge can order a judgement against him but there is no penalty for not paying...that was the point I was trying to get across...In rare cases the judge will garnish his wages but if the dude doesn't have a job then your screwed either way...speaking from experience...never got my money back, but it wasn't $10k either...Good Luck and that dude needs to be shot in the leg...
i took tons of pics i saved text messaages etc thanks to iphone ialready had a shop check it all out i am already bulding a whole new motor gonna cost me alot
i have done this before i been swfd class etc i just was tryingto get back in the game racing again and this **** i did not even own the car 3 days dont worry i will have this delsol running like it should
i already bulding a case i cant do anything to the guy that sold me it i dont want to go to jail now do i for a car
so karma will get him
and i will in court i will also sue big time not small ****
just put dat n!gga to sleep...he needs a long nap...make an example out of him so that people wont try to scam one another no matter how bad the economy is...this is very embarrassing to the racing sports...**** like this str8 kills everything
I hope to hell you have a BOS stating exactly what was supposed to come with the car/motor etc. If he bs'd you then you easilly have a case. If he doesnt show up for court then he forfeits and then you will need to take action in order to garnish his wages.
That is some low class bullshit...
