Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Will any other Honda alternator fit into a 7th gen?
Old Aug 18, 2010 | 03:33 PM
theineffable's Avatar
Default Will any other Honda alternator fit into a 7th gen?
I was looking at the S2000 alternator and noticed that it looks a lot like the civic one but i think it's rated 105Amps instead of 70Amps.
Since I do have a spare s2k alternator, i was thinking of installing it into the civic. Does anyone know if it's compatible or if there are any potential problems w/ using an s2k alternator in our cars?
I wonder if alternator pulley size might be an issue. I'm not sure what rpm the alternator should be spinning at during idle, but i have a feeling that it will change if installed into a civic. The F20c in an s2k idles around 950rpm...
oops made a mistake in the title..it should read..."Will any other Honda alternator fit into a 7th gen?"
Old Aug 18, 2010 | 03:51 PM
baron340's Avatar
Default Re: Will any other civic alternator fit into a 7th gen?
I could be wrong here.. But I believe the f20c spins the opposite direction. I'm not entirely sure if that would matter in a new alternator, but a used one will certainly have issues as the wear inside will be directional and will not like spinning the other way under load.
Old Aug 18, 2010 | 04:36 PM
hmmm...but it'll still function properly...
but speaking of rotation direction, do you know if our alternators have a fan on it?
silron
Jun 18, 2011 01:34 AM
ITR198
Honda S2000
Jun 18, 2008 04:13 AM
freeofparanoia
Oct 20, 2003 08:51 PM
