Low Voltage & Idle Issue
Old Aug 18, 2010 | 01:20 PM
blazin99si's Avatar
Default Low Voltage & Idle Issue
What's up guys I've noticed with the key on the ON position, my voltmeter shows 12.4-12.5. Once I turn on the car the volts clock in at 13.9-14.0 and within about 20-30 minutes of driving they go down steadily to around 13.2-13.4. This is with no additional load aside from my boost gauge, PLX wideband, an Apexi AFC and the voltmeter itself driving around during the day.
At night though with the headlights on and the car idling the volts come in at 12.5-12.8 or 13.0 at best and if I switch the oem foglights on it goes down to anywhere between 12.0-12.2 sometimes lower. With either or on (headlights & foglights), or both, the idle is very rough and sometimes the car shuts off when coming to a stop.
I'm running a 130amp Alternator with a 4 gauge wire going straight to the battery. I was running an Odyssey PC680 battery but have since switched back to a conventional Autostart Gold battery from Advance Auto to see if it was the battery but with no luck, same issue. I've also upgraded the big "3" to 4 gauge wires as well.
I was told that this may be an issue that could be solved by upping the idle but turning the idle screw on the throttle body hasn't helped either. It idles around 800-840 right now so I was thinking about maybe bringing it up some thru Crome to see if that changes anything but any other ideas out there? Anyone have an idea on what voltage I should be seeing with the headlights on & off?
Just in case its a 92 civic with a boosted LS running 1000cc injectors again using Crome, no AC, no PS and running a Fluidamper crank pulley. Any help would be greatly appreciated.
Old Aug 18, 2010 | 01:35 PM
Green Crack's Avatar
Default Re: Low Voltage & Idle Issue
Have you tested your alternator with a load tester?
Old Aug 18, 2010 | 01:53 PM
Former User's Avatar
This sounds like a classic case of bad alternator.
Old Aug 18, 2010 | 02:30 PM
blazin99si's Avatar
The alternator is brand new about 2 weeks old but when I took it to get tested this weekend I was told it checked out fine. Maybe I should take it out and get a second opinion at Autozone or something?
Old Aug 18, 2010 | 02:57 PM
Yeah i would get a second opinion, unless you you or a buddy has one of these,
http://www.toolfetch.com/Category/Au...rs/ASO6042.htm
Love this thing.
Old Aug 20, 2010 | 08:30 AM
blazin99si's Avatar
Alright so I should be able to take it to say an Autozone and they could test it right? Any other ideas?
blazin99si
Aug 25, 2010 06:49 PM
simplsi
Oct 26, 2006 12:25 PM
meconfu5ed
Mar 19, 2004 03:36 PM
Behan
Jul 17, 2003 03:33 PM
gsrstyle
Nov 16, 2002 03:47 AM
