booster replaced...calipers stuck
Old Aug 18, 2010 | 12:31 PM
efsex's Avatar
Default booster replaced...calipers stuck
I just replace my brake booster and my front calipers seem to be stuck partially closed. I bled the brakes and the master cylinder is also brand new. HALP
Old Aug 18, 2010 | 12:59 PM
goldpearleg6's Avatar
Default Re: booster replaced...calipers stuck
time for some new calipers
Old Aug 18, 2010 | 05:29 PM
efsex's Avatar
yeah. i was hoping that wasnt the case...FAULK
Old Aug 18, 2010 | 05:46 PM
casprghst68's Avatar
make sure the the pushrod that connect to pedal is adjusted right. it could be pushing on master cyl not allowing fluid to release. the pin should slip through easy
Old Aug 18, 2010 | 06:45 PM
2-obd1crx's Avatar
yea i had that problem when i replaced my master cylinder and booster, should be a easy fix. good luck
Old Aug 19, 2010 | 02:34 AM
likwid2u's Avatar
make sure the check valve on the vacuum line is facing the right way, if by chance you connected it backwards it will make your brakes lock up
LS stretch
Apr 21, 2010 01:24 PM
thecruzs2007@yahoo.com
Mar 20, 2010 03:52 PM
civicexowner
Jun 18, 2009 03:07 PM
Allurian
Suspension & Brakes
10
Oct 2, 2008 07:41 PM
y49crxsi
Jul 16, 2004 02:14 PM
