My new car have K-Pro?
Old Aug 18, 2010 | 10:39 AM
Budget Racer's Avatar
Default My new car have K-Pro?
Hey wassup peeps I just got an 03 EP3 and was looking at my redline and it's about 7300rpm. Thats about where it should be with a K-Pro mod right, but car is used so not sure. How can I check if I have it? I am concerned because there are two K-pro mods one for 87 octane and one for 91.
If I have the 91 octane K-pro mod and I put 89 octane gas in would it run decent still or detonate? Reason being is ive been using 87 but havent noticed anything weird. But I don't wanna put 87 if I need 91. Any help appreciated.
Old Aug 18, 2010 | 10:50 AM
nahonda04's Avatar
Surje.motorsports
Default Re: My new car have K-Pro?
sounds like you have kpro and there are not two different kpro systems, your cars' kpro may have be set or tuned to 91 octane or 89 octane, take it to a tuner...let them tell you!!
Old Aug 18, 2010 | 11:03 AM
Oh really. I must have misunderstood the info on hondata website. I thought the program was specific to the octane. Thanks for reply dude.
Old Aug 18, 2010 | 11:04 AM
Being scared I put 91 in today it ran just as good and maybe better not sure.
Old Aug 18, 2010 | 12:29 PM
YaBoiTHiZZ's Avatar
A easy way to tell if you have KPro is look at your ECu and see if there is USB port on the back of it...if there is then walaaaa you have KPro...if not then you might just have a reflash...
Old Aug 18, 2010 | 12:32 PM
Thanks Guys very helpful.
You avatar looks like my cat nahonda04 lol.. Peace out Yalls
Old Aug 18, 2010 | 02:42 PM
DaveSi677's Avatar
a 7300 rpm rev limit... doesn't seem like a KPRO or even a reflash.
Reflash give you a 7800 rpm rev limit and I would image the KPRO would be about the same depending on the tuning! I could be wrong but that is from what I know... I would do like the other poster stated as in to check for a usb port on the ECU!
Old Aug 18, 2010 | 03:10 PM
Yeah I think I misread. I just checked it agian and found this.
K20a3 - Rev limiter raised to 7700 rpm. I bet my car just has reflash. I'll check ecu when I find it. Not sure were it is yet.Different from civic ek it seems
Old Aug 18, 2010 | 03:16 PM
DaveSi677's Avatar
Its on the passenger side on the right side corner at the bottom...
Old Aug 18, 2010 | 03:27 PM
Dam hate when post doesnt work and then you do it again and Bam there is two posts!!! F#ck it did go through
Old Aug 18, 2010 | 03:31 PM
Yeah I figured that cuz they r usually ther but maybe was just covered in speaker wire from previous owners crappy stereo install. i'll look again
Guess I'm just an EP3 Noob haha. My other Civic is a 00 CX hatch
Old Aug 18, 2010 | 10:10 PM
I hit the limiter on the way home again to see the redline better and seems to be around 7500-7600rpm but hard to stare at that rpm. Is that rev limit posible with
K-Pro?
Old Aug 19, 2010 | 03:44 AM
dx_rex's Avatar
i think the stock redline is around 6800 but the limiter is 7200ish. if its going past 7500 something has been modded. in k-pro you can set the limiter to wherever you wish i belive.
Old Aug 19, 2010 | 06:57 AM
SkoundrelUSA's Avatar
cute little bastard
Just pull out the ECU and check, the revving test is not the answer nor does it prove anything.
Old Aug 19, 2010 | 07:48 AM
cloumep3's Avatar
Here you go, in case you were wondering how to get to it:
http://www.ephatch.com/forum/showthr...r-(easy)/page6
Old Aug 19, 2010 | 08:34 AM
Yeah you're right found info on wikipedia And yeah I think the limiter is @ 7500. I thought redline and revlimit were one and the same hmmm.
http://en.wikipedia.org/wiki/Honda_C...ept_.282002.29
"Shifting away from the B-series engine, the seventh generation Civic Si adopted the K-series K20A3 engine rated 160 bhp (120 kW) at 6500 rpm and 132 ft·lbf (179 N·m) at 5000 rpm.[12] With a redline of 6,800 rpm, the Si distanced itself from the narrow, high-rpm"
Old Aug 19, 2010 | 08:35 AM
What the hell is this link LMAO!! Just a super weird Noob Thread?
Old Aug 26, 2010 | 04:34 AM
GKsKid's Avatar
why have you not looked at your ECU yet? stop hitting your limiter too.
Old Aug 26, 2010 | 09:22 AM
Because I don't want too. I will when I have time or want to don't worry about it man. I'll hit my rev limiter if I want to as well drive your own car.
Old Aug 26, 2010 | 12:05 PM
hawaiiancb74's Avatar
congrats on having yer own car.. still hitting the limiter isn't good
Old Aug 26, 2010 | 01:17 PM
cute little bastard
LOL you don't have time to pull the plastic piece off with 1 hand then unscrew 2 10mm bolts?
Old Aug 26, 2010 | 02:43 PM
Don't worry about my time. I do it when I want not when sum ***** from Honda-tech tells me.
Man on my old car I hit limiter plenty of times and never had probs doing it. The car can take it I'm sure so don't worry about it I'm not. I don't do it alot though. For me right now it's the only way to find the limiter on my new car.
And yeah I have plenty of other stuff I do besides play with my car.
Old Aug 26, 2010 | 05:59 PM
cute little bastard
Dumbass I could care less if you try to rev up to 9k but it won't prove you have kpro doofus. You prob don't even know where the ecu is. And Now resorted to name calling to save face.
Old Aug 26, 2010 | 07:28 PM
cloumep3's Avatar
not good for tranny...
Old Aug 26, 2010 | 07:32 PM
builthatch's Avatar
MiG-21 superfan
the problem here is you are making people spend more time reading through all this than it would take for you to simply take the panel off and look at the ECU. in fact the retorts you keep posting take more time than checking the ECU.
attacking people for wanting you to get to the point when they are trying to help you is not smart. it makes no sense, actually.
enough of this nonsense.
