95 EG with B16A2 swap need help with smog question
Old Aug 18, 2010 | 05:17 AM
12aNcH's Avatar
Default 95 EG with B16A2 swap need help with smog question
hay guys so i have a 95 eg with a b16a2 swap and i was wondering if i can pass smog? i have everything stock... even the ecu... so i was wondering will it pass no question?
Old Aug 18, 2010 | 06:58 AM
thesmogman's Avatar
Default Re: 95 EG with B16A2 swap need help with smog question
If you are in CA then you need to see a ref and get a BAR sticker first. Then you can have the car smogged normally.
The B16 was not offered in an EG so this is why you need the label. Also you have to run the same computer that was orginally with the motor.
Each state has different requirements. To find out more call the DMV that is closest to you.
Old Aug 18, 2010 | 04:21 PM
12aNcH's Avatar
yeah i am in Cali but i heard that i can pass with the stock motor and the stock ECU with a stock Cat....
EF-junkie
Jan 3, 2008 04:27 AM
slkleltlclh
Oct 14, 2007 11:38 AM
gerard92692
Apr 2, 2004 01:44 PM
Wazup
Feb 16, 2004 02:25 AM
EclipticX
Sep 29, 2003 05:35 AM
