tap size to re-tap b-series crank. what size tap??
Old Aug 17, 2010 | 09:03 PM
j_wod2000's Avatar
Default tap size to re-tap b-series crank. what size tap??
Hello HT. So i've tried looking here and other places on the net regarding my issue and have no luck yet. So im hoping someone here can help me out. Today i removed my crank pulley to replace my timing belt. I used a pulley puller and as I was cranking the threaded bar on the puller, it started threading into the crank pulley bolt hole, damaging the starting threads where the crank pulley bolt threads in. Does anyone know what size tap i need, so i can clean up those threads? All i know is that the thread pitch is 1.25.
Old Aug 18, 2010 | 06:26 AM
BILLETGRIP's Avatar
Default Re: tap size to re-tap b-series crank. what size tap??
if you already know the pitch all you need to do is measure the diameter of the bolt that went into it.
juba_x
Aug 15, 2010 01:50 PM
theineffable
Honda Civic (2001 - 2005)
Jun 18, 2010 09:56 AM
mudchuck
May 17, 2010 07:57 PM
kornerk12
Feb 9, 2007 10:25 AM
