Engine starts.. But only with a jumpstart
Old Aug 17, 2010 | 08:09 PM
jsoccer's Avatar
Default Engine starts.. But only with a jumpstart
Hey everyone, I bought a '91 CRX Si today, and the one problem I have is it only starts when jump started. I'm guessing theres a wire not getting enough juice or the batter, but does anyone have any other ideas what it may be?
Old Aug 17, 2010 | 08:27 PM
dohc4life's Avatar
Default Re: Engine starts.. But only with a jumpstart
need more info
Old Aug 17, 2010 | 08:31 PM
D16SiHatch's Avatar
once it's running check and see what voltage you're getting. if it's below 13.5 then your alternator is not charging the battery. if the voltage is above that however then it may be that the battery is toast. also check your grounds. chassis to front of engine, chassis to tranny, and main engine harness to thermostat. then check the power feed wire coming right off the alternator. make sure it's not loose or broken.
~sp33~'s Avatar
EFB055
Bad alternator, Needs water in the battery, charge leak?
Some ideas.
EDIT: D16 is on the money.
Old Aug 17, 2010 | 09:09 PM
hatchet_honda's Avatar
bad battery? theres a few simple tests that obviously havent been tried yet
Old Aug 17, 2010 | 09:29 PM
jsoccer's Avatar
Could you tell me the tests, this is my first car and I'm working on getting it better. And yes it's a d16z6.
Thanks for the suggestions everyone, will check everything tomorrow
Old Aug 18, 2010 | 11:04 AM
crazyboy's Avatar
do you know how to work a multimeter?
Old Aug 18, 2010 | 11:24 AM
jdm ef8 89's Avatar
Its probably your battery isnt putting out enough voltage but just try tapping on your starter and see if its starts without poping it
Old Aug 18, 2010 | 01:18 PM
CW-ITR's Avatar
There are only three things that could be the cause:
1. Dead battery.
2. Bad contacts (corrosion) between the battery and the wiring.
3. The alternator is bad and doesn't charge up the battery.
GPC91
Oct 3, 2012 03:46 PM
tkda
29
May 5, 2009 02:46 PM
tkewtn
Nov 16, 2007 01:38 PM
haroldthefly91crx
Dec 26, 2006 07:35 PM
macsmurray
12
Jun 14, 2005 02:36 AM
