Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
02 Civic EX service manual in PDF format?
Old Aug 17, 2010 | 07:10 PM
L_U_D_I_AAccord's Avatar
Default 02 Civic EX service manual in PDF format?
Does anyone have or know where I can find 02 civic service/shop manual in a pdf format?
I need to replace my RL abs sensor, but i want to know how to test it first before i run to the dealer and get a new one/ I got code 17 from the ABS light after connecting pin #4 and #9
Thanks!
Old Aug 17, 2010 | 08:36 PM
It Wasn't Me's Avatar
Default Re: 02 Civic EX service manual in PDF format?
Sorry, but we don't offer free copies of copyrighted material.
Edit:
1. Disconnect the ABS control unit 31-pin connector and start the engine.
2. Measure the voltage between terminal #9 (+) and a body ground.
Is there 0.3 volts or more?
Yes - Repair the short in the (+) circuit wire between the ABS unit and the wheel sensor.
No - Go to step 3
3. Turn the ignition off, and check for continuity between terminal #9 (+) and a body ground.
Is there continuity?
Yes - Go to step 4
No - Go to step 5
4. Disconnect the 2-pin harness connector from the wheel sensor, then check for continuity between the positive and negative terminals of the harness and a body ground.
Yes - Repair the short in the positive or negative circuit wire between the ABS unit and the wheel sensor.
No - Replace the wheel sensor.
5. Check the resistance between the wheel sensor (+) and (-)
Is the resistance 450 - 2,000 ohms?
Yes - Check for a loose ABS control unit 31-pin connector. If necessary, swap the ABS control unit with a known-good one and recheck.
No - Go to step 6
6. Disconnect the wheel sensor 2-pin harness connector, and check the resistance between the (+) and (-) terminals of the wheel sensor.
Is the resistance between 450 - 2,000 ohms?
Yes - Repair open in the (+) or (-) circuit wire, or short between the (+) circuit wire and the (-) circuit wire between the ABS unit and the wheel sensor.
Old Aug 19, 2010 | 11:24 AM
Thanks! That was everithing I was asking for!
Old Jul 17, 2019 | 08:00 AM
topshot-rhit's Avatar
No - Go to step 6
Step 5 and 6 appear to be the same (the 2-pin harness was disconnected in step 4 so not sure why they state to do so again in step 6)
Which terminal is needed in steps 2 and 3 for the FRONT LEFT sensor (code 13)? I haven't been able to turn up the wiring diagram for this 31-pin connector.
Old Jul 20, 2019 | 02:43 PM
DTC-11 = Terminal #5 (green/black) RFS
DTC-13 = Terminal #7 (blue/orange) LFS
DTC-15 = Terminal #2 (green/yellow) RRS
DTC-17 = Terminal #9 (yellow/red) LRS
FasterScooter
Honda CR-V & Element
Jan 21, 2013 06:57 AM
juniordc2
Acura TL, RL & ZDX
Jan 4, 2006 06:55 PM
kmcmpb11
Oct 12, 2004 08:47 AM
vtec4gcivic
Dec 1, 2003 02:06 PM
vtec_addict
Nov 11, 2002 10:10 AM
