Need Tranny info for h22 swap for my 94 accord
just need some advice on what to do with my tranny situation befor i put my swap in.....
My boy has an lsd tranny out of a prelude sh that im tryin to get and hes tellin me it wont work with my swap wich is an h22a1 from jdm can anyone give me some advice to point me in the right direction on weather i can use his trans or what the next best trans i can use for this swap any advice would be greatly appreciated...........
Pretty much any trans from 94-02 4cyl. Accord. Or any H trans except the ATTS SH trans.Its not LSD anyway! I suggest the H22 M2F4 or M2A4. If you want LSD, get the M2B4, T2T4 or the T2W4 Euro-R trans for sick acceleration. But the LSD transmissions will set you a bit back $$ wise.
The Prelude SH doesn't have LSD, it has ATTS SH as 92civlude points out. Completely different systems and ATTS isn't exactly desirable.
M2B4 for OEM LSD transmission is going to be the cheapest. Then you can go to aftermarket units for H transmissions (Quaife, KAAZ, OBX, PhantomGrip, etc)
Knightzero7
Transmission & Drivetrain
Apr 10, 2014 02:39 PM
RPM JDM
Nov 12, 2009 06:42 PM
jaysome01
May 28, 2007 09:11 PM
