1999 honda accord oil pressure switch diagram
Old Aug 17, 2010 | 05:40 PM
lilczar's Avatar
Default 1999 honda accord oil pressure switch diagram
I have a cracked connector to my oil pressure switch I"m told. I'm also told the wire harness on is back order indefinately and has been redesigned by honda. I have a bad oil leak and know its somewhere above the oil filter. I really would be grateful if someone has a diagram so I"m certain of what I'm taking off is the proper part.As long as I can temporarily stop the leak i will worry about the wiring harness and getting it creatively taken care of. Anyone have a diagram thats clearly marked for this part to be viewed? thanks, Dawn
Old Aug 23, 2010 | 11:33 AM
gianinline's Avatar
Default Re: 1999 honda accord oil pressure switch diagram
If the oil leak is coming from above the oil filter, check:
1) valve cover gasket;
2) vtec solenoid.
If the connector is actually cracked or broken and is ACTUALLY falling off from the oil pressure switch, then get another connector and solder it in place of the damaged one.
Old Aug 23, 2010 | 11:48 AM
HondaPartsHero's Avatar
Technical Hero
Although this is a B18C engine its pretty identical to the Accord. Here's a pic of the sensor.
jayupark
Feb 9, 2017 06:36 PM
leflore
Apr 26, 2013 04:40 PM
Mishako129
Oct 4, 2012 04:08 PM
mkrieger500
Apr 7, 2009 09:58 AM
Gsir8
Jun 29, 2007 04:46 AM
