Got an alignment but still pulls to the left- have print out
went and got an alignment today but it still pulls to the left. below is the print out . please let me know if you see something out of place. the place told me it was my camber causing it to pull to the left????
Driver front wheel
Passenger front wheel
Driver Rear wheel
Passenger Rear wheel
print out sheet 8mp
http://i42.photobucket.com/albums/e3...4/19b2e595.jpg
i do notice the driver wheel looks like its pushed up to the bumper more then the passenger
Driver front wheel
Driver Rear wheel
print out sheet 8mp
your camber is off on the right for whatever reason. thats the only thing i can think of from the charts. unless your axle is binding.
The reason is that you change the alignment of the car when you get in due to the weight compressing the suspension.
The cross caster could cause a slight pull.
Also, they set more toe in on the driver's side than the passenger side, front and rear, which could cause some pull.
the -2.5 camber is correct for the ride height youre at for the front right.
your hunch on the front left being off is definitely to be of concern. thats not enough camber for the drop you have. that and the position is off leads me to believe youve had some issues there. oddly tho the caster doesnt show to be far off.
look at your control arms. probably the lower one is bent or the compliance bushing is bad. just look.
sitting in car or out of car doesnt matter and is not the problem here.
he's not trying to corner balance it. just get it going straight.
also since youre front left toe was so far off before, im assuming your tire is not longer even either. that also contributes to a bad alignment. did you get new tires?
also, if the left tire is worn different than the right one. getting an alignment and still having a bad (worn) tire on the left could contribute to the pull.
i had it on the lift yesterday
the control arms to my eye look straight or not bent. i guess i will start off doing a lca first and go from there
after looking at the wheel one more time. the driver side wheel sits out more pass the fender then the passenger. just a little bit to notice it
i don't it a pull i think it a steering wheel of center issiue due to un even front toe and as far as somthing bein bent you would have notice it in the sai and included angle
you clearly have more negative camber at the right wheel which would cause a pull to the left. are they adjustable coilovers? regardless, make sure the height is even on both sides. maybe a spring is sagging. i believe ideally, you do want a slight amount more positive camber at the left wheel to make up for the angle of the road. but not a whole degree, as you have there
Have you tried swapping the front wheels side to side, then seeing if the pull goes the opposite direction?
Could be radial tire pull.
Its still pulling because they didnt adjust camber/caster. Toe wont cause a pull, just a crooked steering wheel. If you get the camber close to the same on both sides the pull will go away. Even if there both out of spec as long as there equal the car will drive stait. Also try swapping the tires side to side to see if its radial pull. hope tthat helps
You have over 1 degree difference in camber from fr left to fr right. Takes about 1* of difference to cause a pull...if right side fr camber is more negative than the left, this will cause a pull to the left.
speaks the truth. I had the same situation and it pulled very scary.....
i wish they would even out the camber... i probably will take it in again since its under the 6months/6000miles warranty sears alignment.
so since these tires that came with the car are pretty new. could i just use them in the rear or are they garage?
B20HmongHatch
Suspension & Brakes
15
Dec 10, 2012 09:30 AM
LSteggyguy
Suspension & Brakes
22
Nov 3, 2012 02:49 PM
komat
Aug 17, 2010 02:57 PM
