vss frequency question
Old Aug 17, 2010 | 04:23 AM
pleej's Avatar
Default vss frequency question
does the vss amit a diffrent frequency in diffrent gears , so 1st gear has its own frequency to 2nd and so on or is it just the same frequency in every gear at the same rev's
im looking at buying a digital dash for my eg that works with bikes and cars , it's got a Gear Indicator too so would show what gear im in . how could i wire it up ?
any help would be good
Old Aug 17, 2010 | 11:23 AM
rally25rs's Avatar
Default Re: vss frequency question
I'm almost positive that the VSS just pulses at a certain rate for the speed, regardless of what gear the car is in.
Old Aug 17, 2010 | 01:41 PM
megomaniac's Avatar
gear position, is likely a calculation of rpm, vehicle speed. based on the known drive ratio.
Old Aug 18, 2010 | 12:56 AM
pleej's Avatar
so how does this help me ?
Old Aug 18, 2010 | 09:39 AM
mouab18c1's Avatar
Neptune shows you what gear you are in
Old Aug 18, 2010 | 10:15 AM
Relic1's Avatar
the VSS produces one pulse that indicates a certain amount of rotation of the main gear of the trans.
the ECU (and cluster) calculates the pulses per minute and uses that info to show speed.
the ECU uses the trans ratio setting in the ECU to calculate the speed vs RPM to determine gear.
if you're looking to display what gear you're in, neptune/eCtune with a tunerview works very well.
as far as an input to your setup, depending on what that device uses for an input... you may be able to setup an output to react to gear in neptune, eCtune or even crome.
Old Aug 19, 2010 | 12:44 AM
pleej's Avatar
cool, im using crome so its all good
Old Aug 19, 2010 | 07:20 AM
Relic1's Avatar
I just checked Crome and Crome gold, it's not an option.
I don't have eCtune or neptune handy to check if it's possible with them.
Old Aug 20, 2010 | 11:49 AM
pleej's Avatar
thats no good lol mmmm i will have to look into hondata, id realy like this to work
soninihon
Nov 8, 2015 09:42 AM
nightryder21
May 20, 2003 08:04 AM
R2D2
Jun 17, 2002 07:40 AM
