what exactly is a balance shaft and why do people get rid of them
Old Aug 16, 2010 | 08:28 PM
dustinbs144's Avatar
Default what exactly is a balance shaft and why do people get rid of them
like the title says what exactly is a balance shaft? What is its purpose? and finally why do people seem to always get ride of them? thanks
Old Aug 16, 2010 | 08:35 PM
D16SiHatch's Avatar
Default Re: what exactly is a balance shaft and why do people get rid of them
"The reason that the H22 has balance shafts is because of it's size and relatively bad rod/stroke ratio."
http://www.hondaprelude.to/forums/sh...ad.php?t=22359
and some insight and why they are removed
http://www.preludeonline.com/f69/bal...al-kit-206045/
Old Aug 16, 2010 | 08:59 PM
raidacaipo's Avatar
^^^ read those but in a nut shell the balance shaft mainly found on bigger motors like the h22a are there to help stop unwanted engine vibrations during acceleration. Therefore, its suppose to make driving more comfortable. However, most of the swappers just remove it because they could care less about ride quality when they have stiffer aftermarket mounts that will vibrate the car anyways.
You don't have to totally get rid of it, you can just remove the belt that's on it and it won't rotate anymore. However, people remove them for a clean look and weight reduction. You mainly find these on race setups or h2b owners such as myself
Old Aug 17, 2010 | 08:31 PM
H2b-eghatch's Avatar
as in pulling that whole BS crank out and use that block off plate to cover it up?
Old Aug 17, 2010 | 09:12 PM
kozanatos's Avatar
Yeah, but with the Kaizenspeed kit, you need to have your head off and you need to plug up the holes that send oil into the balance shaft chamber. And then installing that plate also =[ i wish it was that simple.
fastdohc
Oct 4, 2012 06:42 AM
Dravenm4
Feb 14, 2009 02:18 PM
BB6racer
Sep 5, 2005 07:33 AM
satan_srv
Nov 21, 2002 02:15 PM
