can you put an f23a4 into a 95 prelude?
Old Aug 16, 2010 | 07:03 PM
adrfl59's Avatar
Icon6 can you put an f23a4 into a 95 prelude?
i have the block sitting. came with the car, i was reading up on how people boost the engine f23 stock. so i figured, why not dump it into my lude. is this possible? wat would i have to do?
Old Aug 16, 2010 | 09:50 PM
InvaderTrax's Avatar
Default Re: can you put an f23a4 into a 95 prelude?
Drops right in. Uses your stock transmission. You'll want to use the ECU from a 94/95 F22B1 Accord
Old Aug 17, 2010 | 04:03 PM
92civlude's Avatar
Issues with the IAC will arise. The F23 uses a 3 wire rotary and the Lude uses a 2 wire IAC. Youll also have to bypass/jumper the injector resistor if you plan to run the F23 injectors. But if you use the F22 intake manifold, you wont have any of the problems that I just stated.
Old Aug 17, 2010 | 05:46 PM
Kronn 98SH's Avatar
This is pure ignorance on my part as I haven't done anything F-related yet, but why wouldn't you use the ECU for the engine in question (F23A4)?
Old Aug 17, 2010 | 06:30 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
The plugs are comletely diffrent. Also will likely have immobilizer issues. Also OP you will have to convert the engine to obd1. Alt plug is different, injectors are different and distributor is different
Old Aug 18, 2010 | 03:05 AM
I figured it would be easier to convert the engine to OBD1 than convert the car to OBD2
thirsk66
Mar 12, 2013 07:03 AM
dcskater56
Dec 21, 2009 05:27 PM
preludesi2188
Nov 22, 2005 10:24 AM
Layziebtnh055
May 24, 2004 06:29 AM
