Transmission & Drivetrain Gearboxes, Differentials, Clutches
Differential Bearings?
Old Aug 16, 2010 | 05:15 PM
Mel M's Avatar
Default Differential Bearings?
95 Civic EX 5-speed 220,000 miles. Loud drone, increasing with wheel speed, neutral doesn't change the noise, nor does steering side-to-side. Sounds like giant snow tires on front wheels. Any suggestions? Over the last few weeks it's progressed where I won't drive the car. Better to just get another transmission or fix this one? Car was worth about $2000 to me before this happened.
Old Aug 16, 2010 | 10:06 PM
Aquafina's Avatar
Default Re: Differential Bearings?
Pull the axles out and see if the diff has play (not the side gears, the diff itself).
Old Aug 18, 2010 | 12:07 PM
lsef's Avatar
Umm,that sounds like wheel bearings to me...
Old Aug 18, 2010 | 12:21 PM
TheShodan's Avatar
Moderator
Sounds more like wheel bearings are going than anything else
Old Aug 18, 2010 | 04:38 PM
Aquafina's Avatar
Wheel bearings won't have any noise present in neutral (at a stop). Since he mentioned neutral I assumed he meant the noise is present at idle. If its the wheel bearings he would find that when pulling the axles out.
Old Aug 20, 2010 | 09:53 PM
Mel M's Avatar
Sorry I did a bad job describing the noise. I meant neutral at 50 or 60. It did turn out to be a front wheel bearing. I didn't think a wheel bearing would sound like this.
S2Kstuntin
Jan 17, 2010 01:19 PM
norcali707
Honda Civic (2001 - 2005)
Dec 6, 2009 07:25 PM
Jamezvtec
Jun 11, 2009 04:43 PM
Muckman
Sep 30, 2003 06:52 AM
fe519
May 19, 2003 07:29 PM
