cb7 h22 swap cranks but no spark HELP!!!!!!
ok i got a cb7 and i swapped a h22a into it
i finally got it to crank over
reason was the ground from the starter wasnt clean
now another slight problem
it cranks and is not getting spark
im getting fuel
i took a hot wire and tapped into the powerwire on the distruputer and cranked it and it started
it sounds rough due to me not having all of the exuast hooked up and not all the vacuum lines
but i want to know what i should do with the ignition?
im not getting any power to the distrupiter
i used a multimeter and im getting nothign
any suggestions?
im getting fuel
any suggestions?
Brownjd
Feb 15, 2011 08:11 AM
