92 prelude wont crank
Old Aug 16, 2010 | 03:53 PM
pschultz91's Avatar
Icon3 92 prelude wont crank
I drove to the bank and drove home, and an hour later i wanted to go get something so i got in my 92 prelude and tried to start it...... wouldnt start, wouldnt crank. I checked the battery the connection was good and the battery is not dead. so what could it be? please help i have to drive to birmingham tomorrow!
thanks in advance
Old Aug 16, 2010 | 11:17 PM
double wishbone's Avatar
Default Re: 92 prelude wont crank
I can't tell you what it may be exactly, but I can tell you what you may want to investigate. Check out the fuses. I believe there's a 7.5 amp fuse under the dash that is for the stater. Also, in the area, investigate the starter relay, which in my 95 Si is the top left relay in that area. If these check out ok, does the car have a manual transmission? If so, inspect the clutch interlock switch, which is the safety mechanism that prevents the car from being started without the clutch pedal being depressed. The interlock switch should be fairly easy to locate.
This advice is all assuming the car runs but not starts. If so, I'm having the same exact problem with my Prelude...I can push start it, but the starter isn't working. I don't suggest you try to push start the Prelude unless you have a hill and a few people, it's a heavy car. I hot-wired my starter and it started to crank. Give that a shot too and see if it starts to turn over.
Good luck, I hope you get it started.
Brieana
Oct 16, 2018 10:34 AM
Erikrod11
Aug 9, 2017 07:56 PM
300k
Oct 28, 2015 10:59 PM
Amanda7289
Dec 31, 2014 11:37 AM
