can somebody name this part?
Old Aug 16, 2010 | 01:54 PM
team_ibR's Avatar
Default can somebody name this part?
its hold by two 17 bolts. The brake pad sits on them. Need the help asap.
Old Aug 16, 2010 | 02:46 PM
xalents23's Avatar
Default Re: can somebody name this part?
Brake caliper.
Old Aug 16, 2010 | 04:00 PM
Shimakid12's Avatar
It's the brake caliper bracket. It holds the caliper to the knuckle and pads in alignment with the rotor and caliper. The sliders on the brackets allow the caliper to sort of move forward and backward based on rotor/pad thickness and piston brake force. What was it that you needed to know the name of it for? Most places don't sell replacements as they aren't really a wear part. The slider pins should be removed when servicing the brakes for re-greasing to keep from seizing. Hope that helps.
Old Aug 16, 2010 | 04:04 PM
95itr-ej2's Avatar
how did you manage to brake that
Old Aug 16, 2010 | 05:31 PM
mouab18c1's Avatar
break
Old Aug 16, 2010 | 06:01 PM
rally25rs's Avatar
wow, I've never seen someone break one like that. You'll probably have to buy a whole caliper, or junkyard just the bracket.
Old Aug 16, 2010 | 06:12 PM
Shimakid12's Avatar
Oh wow...I didn't notice the picture with the broken one...that's pretty crazy. It's going to be hard to find one new, but a used one shouldn't be too hard to come up upon. Good luck.
Old Aug 16, 2010 | 07:23 PM
mouab18c1's Avatar
All Integra calipers should work.
Old Aug 17, 2010 | 06:45 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
There should be a number stamped somewhere on there that says t-22 or t-25 or something similar. This will tell you which car you can get the bracket from as many honda and acura models shared brake set ups.
Old Aug 18, 2010 | 12:37 PM
JdmOdz's Avatar
BRAKE CALIPER BRACKET
IntegraType-R
Jul 31, 2007 09:11 AM
turbohf
Jul 20, 2005 10:19 PM
nsxtasy
Jul 6, 2003 09:45 AM
