NO dash lights in 91 hatch.
Old Sep 17, 2002 | 07:19 AM
Chris's Avatar
Default NO dash lights in 91 hatch.
Is this a common problem? or am I going to have to figure it out??!!
I just picked up a 91 Hatch (CX???) it has vinyl seats and the VIN says ED(chassis code?).. It was made in Canada...
200,000 miles.
Old Sep 17, 2002 | 07:37 AM
SuperCivic's Avatar
Default Re: NO dash lights in 91 hatch. (Chris)
check fuse block. then check dimmer switch.
Old Sep 17, 2002 | 07:44 AM
Chris's Avatar
Default Re: NO dash lights in 91 hatch. (SuperCivic)
Dimmer works.. fuse ok. The lights for the heater controls work (with dimmer also)
I suspect a couple bulbs out. The lady said it was intermittent, so I figured it might be common.
Old Sep 17, 2002 | 08:05 AM
rpr's Avatar
rpr
I had the same problem when I did a teg wiring harness into a 1G CRX. I found a little control box or something like that attached to the back of the teg dash, about 2"x2"x.5" , near the heater controls/radio area. Without that thing plugged in, the dash lights didn't work. Just a thought.
Old Sep 17, 2002 | 08:09 AM
SuperCivic's Avatar
are the taillights out too? they're connected to the same fuse.
the little lights in the cluster are very easy to change.
Old Sep 17, 2002 | 04:15 PM
mr. carpenter's Avatar
same problem when i bought mine. remove steering wheel and steering shaft covers. remove gauge cluster enclosure. remove cluster. change bulbs and wipe down all places on circuitry that look to be contact points. i put colored bulbs in since i was already in there but you can only see the right side of the speedo lit up blue. anyways i did this and mine came on. what sucks is you do the work and than you've to wait until dark to see if it worked. i've not got into the heater control yet but mine is out also , but only the top half . weird. hope this helps . if i've been too vauge i.m. me or go get a chiltons or haynes book . good luck.
[Modified by mr. carpenter, 1:18 AM 9/18/2002]
Old Sep 17, 2002 | 07:50 PM
Chris's Avatar
Default Re: NO dash lights in 91 hatch. (mr. carpenter)
Cool. Thanks. I need a new wheel anyway (its sll mushy and twists in my hands)
I will do that. I had to do it in my old 240SX as well...
I know what you mean on the heater controls.. the part that has the fan speed is dark and I have to hit it to get the rest to come on!!
200,000 miles is tough on electronics!
Old Sep 17, 2002 | 07:55 PM
Louie B.'s Avatar
this may help you get to your bulbs....
http://groups.msn.com/Thumpu77sphotos/guageswap.msnw
by the way... your civic is a STD model (Vinyl Interior)
[Modified by thumpu77, 8:57 PM 9/17/2002]
Old Sep 17, 2002 | 11:12 PM
Chris's Avatar
Default !Q
Thanks! I thought so.. no radio or cig lighter... really stripped!
Old Sep 18, 2002 | 12:28 AM
tysf's Avatar
Default Re: NO dash lights in 91 hatch. (thumpu77)
if it was sold in canada it would be a cx... which is just a STD with a cx badge
he said it was built in canada (which i believe every civic from 91 on is) built and sold are obviously 2 different things though
Old Sep 18, 2002 | 12:31 AM
boostinb18's Avatar
Default Re: NO dash lights in 91 hatch. (tylerspec)
you dont really need to pull the steering wheel to remove the cluster......if removed my cluster many times and i havent had to remove the steering wheel.....and i bet its just the lights burning out! mine had a few out too.
good luck.
[Modified by boostinb18, 9:31 AM 9/18/2002]
Old Sep 18, 2002 | 07:48 AM
Chris's Avatar
NO badges anywhere... VIN starts with a 2.
I know about the wheel, ill replace it anyway. Thanks for all the input guys.
what I really like if the "Fuel Injection!!" LMAO!! It a carb that squirts gas in as opposed to drip.. hehe
Old Sep 18, 2002 | 09:44 PM
Louie B.'s Avatar
DPFI.. Dual point fuel injection..... also the main reason the engine only puts out 72 hp at the crank. the throttle body is so small that it creates a bottle neck. If you want to up the HP, do a search for MPFI swap.
Old Sep 20, 2002 | 11:59 AM
Chris's Avatar
Thanks.. I have read lots on that already. Sounds great, but at this point I dont want to push this tired 200K motor any harder than I have to. If I want power.. Ill just get a swap. hehe
Old Sep 20, 2002 | 12:52 PM
Trinity's Avatar
there is nothing wrong with that 72 horse motor, you just let me know when you wanna sell it
Old Sep 20, 2002 | 01:56 PM
Chris's Avatar
Default Re: NO dash lights in 91 hatch. (Trinity)
Thanks Trin.
Im putting new ALT, Timing belt and Axles... Ill have to do the top end gaskets real soon. I plan on keeping this car relatively stock (HA!! Thats what I said about my ITR !!)
Im sure Ill get another 100K on this motor!
Old Sep 20, 2002 | 02:07 PM
SeaBass's Avatar
From: Clueless like Shaggy n Scooby before commercial, break
hey, i know nothing of electical components so i need some help on this somewhat related topic. My parking lights don't come on in the front. Where is the fuse located and what exactly is involved in resetting/fixing it. I have a 91 DX hatch
thks
Old Sep 20, 2002 | 04:44 PM
Chris's Avatar
Default Re: NO dash lights in 91 hatch. (SeaBass)
The ones beside the headlights?
The ones in the bumper only come on when signaling a turn.
Old Sep 20, 2002 | 05:02 PM
SeaBass's Avatar
really? oops, my bad. i thought they should come on when the parking lights are on. so, no lights in front should come on when the light switch is in the middle position?
Old Sep 20, 2002 | 06:07 PM
Chris's Avatar
Yes... the ones right beside the headlights (On the outside corner) should be on.. NOT the lower ones in the bumper.
If those are not on when the headlights are on (Switch turned all the way) then I would suggest its the bulbs.
717DC
28
May 9, 2014 06:21 PM
VTECtravler
13
Oct 4, 2006 07:51 AM
futurefastguy
Sep 8, 2006 06:31 AM
skiracer8148
Feb 20, 2006 11:04 PM
Vtec77
May 27, 2005 07:29 AM
