FS: 100% built motor for boost, shaved EM1, TONS of parts
I would really prefer to just sell the project as a whole, but i doubt it will happen. i am losing my house in these hard times, and the project just has to go. i am letting it go only for what i owe on the car itself, and i'm CLEARLY losing my *** on all the money/time invested in the project...I owe $7k. take it ALL how it sits.
99 MR EM1
Brand new 17" rims/tires
APR F1 carbon fiber mirrors
billet motor mounts
FRESHLY shaved bay all seams welded, and headlight holes paneled over and welded
currently the car is gutted, no dash and NOTHING in the bay besides the suspension which is finger tight to roll it onto a trailer, and the rack&pinion
the b16b motor is BULLET PROOF was beeing built for 700whp if you're from Ohio you probably know of Slowmotion motorsports, the motor was build by their old engine builder Scotto who is now a lead tech @ Roush honda...its LEGIT and was being build for his own race car...
the motor ALONE is worth over $7k if you see what alls in it...
Darton MID sleeved B16B block @ 84mm w/ copper o-rings
ERL 5-main girdle w/ arp studs
Scat 95mm Crank
Crower billet rods
CP 9.7:1 pistons
Custom Cometic MLS headgasket
1/2" ARP head studs w/ custom dowel pins
b16 head ported and polished, combustion chanmbers de-schrouded to 84mm
manley inconel exhaust valves
manley stainless steel intake valves
supertech dual coil springs
supertech titanium retainers
Comp stage 4 turbo grind cams
NEW OEM PARTS:
usdm B16 valve cover
oil pan 10an return bung tig welded to pan
oil pickup
oil pump
water pump
timing belt
tensioner
tensioner spring
tensioner bolt
H22 LMAs
camshaft seals
front and rear main seals
sidecover
sidecover gasket
valve cover gasket
oil pump pickup gasket
oil pump o-ring
main and rod bearings
thrust washers
cam gear keyways and bolts
oil pump bolts
water pump bolts
ALSO have polished top mount mani, polished Precision GT35R, NEW port matched Edelbrock IM and hondata IM gasket, Tial BOV, Tial 44mm WG, RC 1000cc injectors, Walbroh 255 pump, GSR trans, Skunk 2 full coils (ride like ****, think their blown), hondata s300. full 3" exhaust, 3" downpipe. car has full interior with an aftermarket steering wheel, i have the OEM wheel and airbag unit still as well...if you're interested TEXT ME, its your best chance of getting ahold of me. #317-408-5206
99 MR EM1
billet motor mounts
Scat 95mm Crank
Crower billet rods
CP 9.7:1 pistons
NEW OEM PARTS:
oil pickup
oil pump
water pump
timing belt
tensioner
tensioner spring
tensioner bolt
H22 LMAs
camshaft seals
sidecover
sidecover gasket
valve cover gasket
oil pump o-ring
thrust washers
oil pump bolts
water pump bolts
you can click my build thread in my sig to see more pix of the progress on the bay shave and the over all car, currently i would recommend replacing the fenders cause the side marker install was sloppy...the bumper and hood just need installed...but if i were keeping it i would have resprayed the whole car to match the freshness of the bay.
why not use a b16b?!
WHY NOT BUY THIS BEAST OF A MOTOR!!!
if i can find a buyer for JUST the motor i will part out the rest of the car, i REFUSE to take less than $5500 for the motor...it's assembled ready to slap a trans on it and take as much boost as you can throw at it...this motor made 591whp on 19lbs with a 60-1 turbo...
ITS A MONSTER...
ITS A MONSTER...
ITS A MONSTER...
ITS A MONSTER...
Good luck, but it's gonna be very hard to sell. I have a soild DART motor, my block alone is 2500. And I can't find a buyer for my asking price of 4600.
4600 completely assembled? with a head? this thing is stroked to a 2.2l and has a fully built race head with portmatched intake mani
also have the following parts;
annodized black billet motor mounts w/red bushings
brand new 17" konig twilight flat grey w/red stripe 205/40r17 kumho's
the fully build motor/head with portmatched edelbrock IM
1000CC rc injectors
Tial black BOV
Tial 44mmWG
slowmotion motorsports top mount mani
3" downpipe
intercooler & piping
polished gt35r
ecu with hondata s300
i'm sure i'm forgetting stuff...or like it says $7k and the whole things yours.
1000CC rc injectors
Tial black BOV
Tial 44mmWG
3" downpipe
polished gt35r
1000CC rc injectors
Tial black BOV
Tial 44mmWG
3" downpipe
polished gt35r
1000CC rc injectors
Tial black BOV
Tial 44mmWG
3" downpipe
polished gt35r
