B18a1 swap help...
Old Aug 15, 2010 | 09:04 PM
nicknack25's Avatar
Default B18a1 swap help...
Alright, i got a 90 crx dx. Swapped the d15 and put in a b18. I followed this website (http://hondacrx881.tripod.com/mpfiswap.html) to deal with the wiring. almost certain my cousin and i did it right but when i tried starting it up today, nothing... lights were on, check engine light was going crazy, once i switched the key to on, i heard something clicking and sounded like it was under the dash and the ecu light was flashing. i dont hear the fuel pump go on either.. im not sure what the problem is. everything is connected besides the o2 sensor cause i couldn't find mine but thats it. help please...
Old Aug 16, 2010 | 12:52 PM
scavengerscrx's Avatar
Default Re: B18a1 swap help...
Im pretty sure I know what it is.
I had the same problem when I was doing a swap.
You need to find all the ground wires, I think there should be three. one goes to the head cover, one goes to the tranny and the last one goes on the back side of the motor on the passenger side of car and it should connect to the water pump.
If any of those are not hooked up then it will do that and will not start, it makes that noise because it is trying to tell you something is not right.
if you need any more info let me know and let me know if that fixes it. thanks
Old Aug 16, 2010 | 09:47 PM
nicknack25's Avatar
YESS!! i seen a ground back there near the water pump but i wasnt sure where it hooked up at! thank you! i will try that in the morning and hopefully that would work.. thank you a lot!
Old Aug 17, 2010 | 05:43 PM
nicknack25's Avatar
Well no luck. That ground cable i seen did help out with the check engine light but yet nothing. Everything was on all the lights, heard the fuel pump this time, still hear the starter clicking, but no crank or anything.. i am not sure what the problem is. im guessing its the wiring but i went over every step 3 times..
Old Aug 17, 2010 | 06:44 PM
D16SiHatch's Avatar
try cross checking what you did with this writeup here
http://hondaswap.com/swap-articles/d...writeup-49557/
the last ground the guy above was talking about is not near the waterpump, that's by the timing belt. i can only assume he was referring to the thermostat housing. and yes it's extremely important that that ground be hooked up.
at this point is your CEL on?
also, you should keep in mind that the no cranking issue is directly related to the starter itself, ignition switch, and the main power/ground wires, and nothing else. i say this so you know that the ecu and mpfi wiring is not a reason for it to not be cranking. you could remove the ecu and set it on the trunk and the car will still crank over.
Old Aug 17, 2010 | 07:54 PM
nicknack25's Avatar
What do you mean by "CEL"? Its weird though because the first day i got the car with the engine in it, it started on the first crank.. Thats why i was doubting that it might be the starter. But i will check that. Actually, i've had the same problem with the d15 i've had before this swap. I would always hear the starter click and then i would keep starting it and eventually it started. Do you see a problem there?
Old Aug 17, 2010 | 08:06 PM
D16SiHatch's Avatar
cel = check engine light.
the starter clicking might simple be that the solenoid is failing. i've had this issue on both my honda's. replaced 3 remans and now the brand new starter is doing it to. it's really getting annoying at this point.
Old Aug 17, 2010 | 08:12 PM
nicknack25's Avatar
oh no that was fixed when i connected the ground to the thermostat.
Old Aug 17, 2010 | 08:28 PM
D16SiHatch's Avatar
so it cranks fine now, but won't start? and the check engine light is on or no?
Old Aug 17, 2010 | 08:30 PM
nicknack25's Avatar
Oh i meant the check engine light was fixed. Its not on anymore. But it still does not crank.
Old Aug 17, 2010 | 08:37 PM
D16SiHatch's Avatar
ok. so you say it clicks? if it's not a loose ground then i would bet it's the starter solenoid. in which case you'll need to replace the whole starter.
Old Aug 17, 2010 | 08:42 PM
KillerHippy's Avatar
Or you could quick fix that by just hitting the starter with something. My truck does that sometimes and it starts right up.
Old Aug 17, 2010 | 08:51 PM
D16SiHatch's Avatar
well sure you could do that, but that doesn't really fix the problem now does it
Old Aug 17, 2010 | 08:52 PM
nicknack25's Avatar
Yeah it clicks. nothing is lose at all. Yeah im thinking about just getting a new starter cause this whole engine has been a damn pain. A problem always with my car..
Old Aug 17, 2010 | 08:53 PM
nicknack25's Avatar
i was even hitting the starter but it wasn't working.
Old Aug 17, 2010 | 09:07 PM
hatchet_honda's Avatar
is the ground wire attatched to your trans?
Old Aug 17, 2010 | 09:45 PM
nicknack25's Avatar
Thats the same ground thats connected to the batt right?
Old Aug 17, 2010 | 10:04 PM
crx_si-r's Avatar
yes. the ground wire coming off the battery goes to the chassis (just under the battery) then to the transmission by the clutch cable.
Old Aug 17, 2010 | 10:05 PM
nicknack25's Avatar
yeah got that one.
Old Aug 17, 2010 | 10:16 PM
crx_si-r's Avatar
are all your fuses good???
Old Aug 17, 2010 | 10:17 PM
nicknack25's Avatar
Yeup checked em earlier today.
Old Aug 17, 2010 | 10:24 PM
crx_si-r's Avatar
your using a B-series starter right? if so have you checked to make sure your getting a good connection on the starter signal wire (female terminal connected at the solenoid)?
Old Aug 17, 2010 | 10:26 PM
nicknack25's Avatar
Yes i am and i have not done that yet. i will try it as soon as possible
Old Aug 17, 2010 | 10:28 PM
crx_si-r's Avatar
sorry i had to ask. i know on my old harness the terminal connecting to the starter would make a crappy connection and from time to time it would slide off. so every now and again i would have to reconnect the terminal to get my car started.
Old Aug 18, 2010 | 12:59 PM
nicknack25's Avatar
alright is cranking now but not starting.. have no idea what the problem could be now except the distributor wiring. anyone know exactly what it is? i just matched it all up. even did the CPS wires.
