Suspension & Brakes Theory, alignment, spring rates....
Which coilovers with 5 lug conversion.
Old Aug 15, 2010 | 06:22 PM
blks2k3's Avatar
Default Which coilovers with 5 lug conversion.
I have a 97 civic hatch with a complete type r 5 lug conversion. When I buy a coilover setup should I just by the one for a 97 hatch? I can get a set of tokico illumina's for a eg would it be ok if I run those because I can get them pretty cheap from a friend.
Old Aug 16, 2010 | 04:59 PM
98civdx's Avatar
Master Detailer
Default Re: Which coilovers with 5 lug conversion.
Buy them for the car, unless you have the function lca's to use a type r style shock. In this case you will need the type r rear shock.
Yes you can use a eg shock, useing a few washers on the fork in back is required but everything else bolts up perfectly.
cayman_hatch
Aug 15, 2005 12:54 PM
TURBO DC2
Jul 28, 2005 07:52 AM
FiZZ-EP3
Jul 15, 2003 02:26 PM
