Is an AEM CAI insulated?
Are AEM CAi's insulated to keep the air cold? if not could you wrap some kinda insulation around it to keep it cold?
insulated = keeps things warm
shielded = keeps things cold
yes, you can (and should) wrap some heat-reflective material around your intake to keep the engine heat from warming your incoming air. header wrap from JEGS or Summit works real well for that. good question, though
There's my short rant
Do you think the ceramic coating is enough to stop the air from being heated? I would like to try and wrap it with something to keep it icy cold.
Also another question.... kinda dumb, but anyways,. In winter, In Canada its phucking freezing. Im wondering because its so cold outside does this make my SRI a CAI??? lol, seriosly, does the freezing cold air outside help? performance?
Guest
Posts: n/a
The air will only heat up to about ambient temperature. Take a metal pipe with running water...put a blowtorch to the pipe. Do you think the running water will be in the pipe long enough to be significantly heated? Not really.
SRI become a CAI? I'll leave that question alone...
From: kapalua,los angeles,las vegas, HI,CA,NV, United States
the aem cai is ceramic coated with a high temp resistance...and i have used foil wrap from home depot with a rated r temp which really helped my intake from getting hot... just my 2 cents
I heard the ceramic coating is looks only, not really funcional, is this true. What do you think??? should I just Buy an AEM or go for the ghetto ractive at half the prince?? Its all the same ****, right?
