Anyone tried a B20Z head on an B18b block?
Old Sep 17, 2002 | 06:15 AM
LSBeast's Avatar
Default Anyone tried a B20Z head on an B18b block?
I hear this little swap works wonders.
Old Sep 17, 2002 | 06:20 AM
JediPimpCrx's Avatar
Default Re: Anyone tried a B20Z head on an B18b block? (DonkeyDick-si)
The only swap i have heard of is the B20Z block and B16A head. Do you have anyinfo or links for what you said?
Old Sep 17, 2002 | 06:23 AM
LSBeast's Avatar
Just know my friend did that swap this past week at the shop and the customer noticed a big diff.
Old Sep 17, 2002 | 06:55 AM
DSF's Avatar
DSF
I didn't realize there was even the slightest difference between the two
Old Sep 17, 2002 | 07:40 AM
SuperCivic's Avatar
Default Re: Anyone tried a B20Z head on an B18b block? (DSF)
*copied from B20 tech section of hybrid2.honda-perf.org*
B20B/Z Head
The B20B/Z head looks to be the same as a B18B (P75) head. The combustion chamber bore is 81mm, while the block and head gasket are 84mm.
Old Sep 17, 2002 | 07:42 AM
DSF's Avatar
DSF
Default Re: Anyone tried a B20Z head on an B18b block? (SuperCivic)
Hehe, that's what I was trying to get at. I just didn't feel like searching for an actual quote
dustin's Avatar
B20 head = P75 head
Unless the B20 head didn't have bent valves or something, he would have noticed absolutely no difference. The casting is the same.
Old Sep 17, 2002 | 09:44 AM
customx_'s Avatar
New User
LS/b20 heads gets no love
Old Sep 17, 2002 | 09:46 AM
Charlie Moua's Avatar
Default Re: Anyone tried a B20Z head on an B18b block? (mindtrix)
ture =dhat.
I second that.. B20 and LS head are the same.
Old Sep 17, 2002 | 10:01 AM
LSBeast's Avatar
Default Re: Anyone tried a B20Z head on an B18b block? (dustin)
so its the same? !
Well that customer got fu#Ked
Thanks for the info guys
Old Sep 17, 2002 | 06:44 PM
StorminMatt's Avatar
The B20 head is the same as the B18B head. But not the B18A head. The B18A head has smaller ports. Also, I think the cams are different.
clevelee
Dec 3, 2008 11:53 PM
DAfireman
Nov 25, 2004 10:17 AM
fasterthanU
Jun 4, 2004 04:24 PM
BrazzNuccolz
Jun 16, 2003 05:23 PM
Chuji
Sep 6, 2001 05:25 PM
