general cooling system question
Old Aug 15, 2010 | 01:01 PM
soon2bdropped's Avatar
Default general cooling system question
okay just a general question. You know how must thermostat is located in the upper radiator hose. so normal operation. upper radiator hose is hot as the thermostat opens up and lower radiator is returning cooler coolant to the engine so its not as hot.. luke warm. now lets say u have an offbrand vehicle. lets say a vw for instance where the thermostat is located in the lower radiator hose. will the lower be hot and upper hose be cool( not as warm) im assuming thats the way it would work right?
Old Aug 15, 2010 | 04:00 PM
fcm's Avatar
fcm
Old Fart
Default Re: general cooling system question
Would make sense, the thermostat "controls" coolant temp. in engine, not in the rad, flow would have to be from the engine, but seems to me that pumping water to the top of the rad makes more sense. 94
Old Aug 15, 2010 | 05:32 PM
honestly you just lost me there?
Old Aug 15, 2010 | 05:55 PM
Targa250R's Avatar
be professional
Every Honda engine I have seen has the thermostat located on the engine end of the lower rad hose. Coolant flows out of the engine via the upper rad hose, and returns from the radiator via the lower hose. Thus, the upper hose is always hot, while the lower hose stays cool until the thermostat opens, at which point it heats up. The lower hose will be a little cooler than the upper hose, but it's often difficult to tell a difference in temperature by hand since they will both feel pretty hot.
Old Aug 15, 2010 | 06:03 PM
yes. toyota have the thermostat in the upper radiator hoses. So i was confused. so doesnt really matter where the thermostat is right? both hose will be hot.. just the hose where the thermostat is will tell me if it has opened or not correct?
Old Aug 15, 2010 | 06:18 PM
Targa250R's Avatar
be professional
It depends on how the system is designed.
I don't know how the Toyota systems are set up, but if they use a radiator that flows vertically (like the Honda systems do) with the thermostat located on the engine end of the upper rad hose, then both hoses will remain cool until the thermostat opens and the hot coolant then circulates into and out of the rad.
To simplify things, the cooling system is basically just one big closed loop, and the thermostat is the valve that controls circulation. When it is closed (cold), coolant does not circulate. When it is open (hot), coolant circulates. It doesn't really matter if the thermostat is located in the inlet or the outlet of the rad; if it's closed, the coolant won't circulate through the rad.
93CamaroLT1
Jan 11, 2010 02:59 PM
Joseprz
14
Aug 25, 2009 05:05 PM
eric416
Apr 10, 2008 05:42 AM
fanta!
Aug 14, 2005 02:14 PM
Import Tuna
May 19, 2004 05:12 PM
