Transmission & Drivetrain Gearboxes, Differentials, Clutches
'99 Odyssey Transmission Teardown
Old Aug 15, 2010 | 12:43 PM
PaulN's Avatar
Default '99 Odyssey Transmission Teardown
So, I've decided to rebuild the transmission in our 1999 Odyssey. The van has 190,000 miles and it was eating a countershaft bearing. I have it out of the van, on the bench, and I can't get the cover off. Attached is a pic of the driver's side of the tranny, and the angry cover. I've removed all 17 fasteners, the soleniods, harness, and I've *massaged* the cover with a block of wood and hammer. It won't budge.
Did I miss a fastener, or do I need to pry it off?
Old Aug 28, 2010 | 08:26 PM
chrisarnt's Avatar
Default Re: '99 Odyssey Transmission Teardown
Any idea what the operating temp of that trans should be?
Old Oct 15, 2018 | 04:56 PM
eksine's Avatar
check if the range sensor has a bolt holding the end cover on, get your block of wood and go along the edges and bang on it to impact stuck pieces apart. watch the honda rebuild and teardown video from guirez on youtube
Old Oct 17, 2018 | 04:02 AM
IndyTeg's Avatar
Remove the transmission range sensor and see if that helps (removing this switch is actually the first step of the overhaul procedure) . There are a total 16 cover bolts, make sure they're all out. This should be all that needs to be removed in order to take the cover off.
big_poppa492004
Aug 30, 2008 12:30 PM
ziptie
Jul 15, 2007 03:33 PM
whp
Mar 11, 2007 12:53 PM
SpiceyRice
Feb 12, 2005 07:13 PM
1.8tgsr
Feb 11, 2005 07:26 AM
