98 VSM complete shell complete b18b, coilovers, sway bar, turbo parts, seats, etc
Located in San Diego CA. Local pick up prefered but shipping can be arranged. Ill bad adding more parts as the part out continues.
The Shell itself is also for sale if anyone is interested. OG wheels and lip and mirrors are no longer on the car.
Progress 24mm Sway with endlinks....170obo
Pair of F1 spec buckets with rails. 350obo for both. some scuffs but in good overall shape. Comes with the wear pads.
tdm x bar...sold
DC2 Carbon APR mirrors...SOLD!!!
Ksport 36 way adjustable coilovers...had them for 2 yrs...handles fantastic...500obo. I can lower the price if you want to trade your stock suspension.
NEW rota slipstream 15x8front +40 offset 15x7.5 +20 so the stance looks decent. The tires are brand new sumitomos I forgot the tire specs but there is a slight stretch. The rims and tires are brand new except a scuff on the rear passenger side rim where I nicked it coming into my garage. hardly noticeable...500obo
Engine &Turbo parts fs
Complete B18b (113000 miles I have the original cluster to prove it) + stock exhaust + stock ecu...only thing missing is the air intake and the injectors(which I might have laying around somewhere) Timing belt and waterpump done not too long ago and I also did a valve adjustment...only fed mobil1...1000obo
Jet coated Drag log manifold with 3 inch downpipe + wastegate elbow...160obo
straight pipe + wastegate dumptube + wastegate elbow...SOLD to SD-EK
(NEW) obd2a > obd1 ECU conversion harness from phearable...SOLD to SD-EK
obd1 b18b1 ECU with Basemap from phearable.net chipped and socketed for tuning. I set the launch control at 5500 I believe and has a CEL shift light. $150obo
air research T3 60/48 off a ford thunderbird. quick spool.....obo
Tial 38mm wastegate with 5psi spring....160obo
aluminum charge piping with couplers and clamps with intercooler (new)...160obo
550cc RC injectors with jumper harnesses so no need to cut and run resistor box/injector plugs...250obo
255 lph fuel pump....SOLD
fast turbo vacuum manifold obo
HKS SSQV blow off valve with injen intake pipe with HKS flange...200obo
motorolla 2.5bar map sensor...SOLD to SD-EK
moroso oil pan (5 quart)...200obo
Stainless steel oil feed and return...SOLD to SD-EK
autometer boost gauge (NEW without box)...obo
civic half core radiator to fit turbo manifold. Used for 5 miles driving up and down my block.... 80obo
tdm x bar...sold
