How easily will a molded lip crack?
Old Aug 14, 2010 | 10:30 PM
florida's Avatar
Default How easily will a molded lip crack?
Hey there. I'm wondering how easily the bondo/putty part of a front lip will crack on a molded lip? I am planning to mold mine onto the bumper, but do not want to do it if the molding will crack when I hit bumps or autocross cones. Thanks in advance.
Old Aug 15, 2010 | 01:57 PM
Pothole987's Avatar
Default Re: How easily will a molded lip crack?
any bump will problaly crack is unless you can use some flexible stuff.
Old Aug 15, 2010 | 02:12 PM
DC2.2_GSR's Avatar
even with "flexible" fillers, it will still crack. the only way to get it to be more elastic like the plastic bumper is to do all of your molding with flexible, durable plastic repair materials like some of 3M's stuff or the Crest stuff we use. Crest Code Blue (for flexible bumpers) or even Crest Redline Rigid expoy will work. then just do very minimal filler work and prime it.
like i said though, it will still crack if you hit it or twist it hard enough. curbs and cones > thin plastic bumpers. lol
Old Aug 19, 2010 | 05:40 PM
Fibercation's Avatar
get a fiberglass bumper and lip and fiberglass it
Old Aug 20, 2010 | 09:01 AM
Pothole987's Avatar
still crack and chip with any little BUMP.
Old Aug 24, 2010 | 06:53 PM
spray2020's Avatar
he said fiberglass bumper molded to a fiberglass lip...
fiberglass bonded to fiberglass, using fiberglass as the bond material with proper prep will not crack. It will become one whole fiberglass piece.
It wont crack where it is molded, but yeah- fiberglass in general can crack if its hit.
Old Aug 25, 2010 | 09:06 AM
IMPATIENT's Avatar
Will be able to help you with much more certainty if... I know what the front lip is made out of, and what the bumper is made out of.
is it an oem bumper or an aftermarket bodykit made of fiberlgass, frp etc.
is it a urethane lip, fiberglass lip, abs plastic ?
any combination will require a different chemical adherer topped off with a flexible poly topcoat to finish the bodywork before primer. Fiberglass,well, just dont ever mold it. Even with a little bit of body flex or pressure it will cause cracking and seperation at the mold site.
EG-SIXV-TEC
Paint and Body
Mar 12, 2012 11:48 AM
legends
Jan 19, 2006 10:27 PM
digital sol
Welding / Fabrication
Mar 16, 2005 08:01 PM
ekdriven
Jun 6, 2004 12:05 PM
