Help Needed to complete B20A Swap---Erratic Idle!---
So I while back I started a JDM B20A Swap into a 1989 Si. I got as far as swapping the motor but I was not able to finish everything because I left to college. Well now I'm back home for the summer and I'm picking up where I left off.
The problem I'm having is extremely erratic idling.
I'll give you a break down of what the car has right now
Break down:
So, I have a 1989 Honda Prelude SI 4WS, I have swapped into it a JDM B20A. It has:
- JDM B20A motor
- USDM Transmission
- USDM Intake Manifold (ITM)
- USDM Exhaust manifold (EM) [with all o2 sensors, which connect to the (EM)]
- USDM Speedometer cable since I am running the USDM transmission
Problem:
I have started the car successfully and it drives fine, however when it comes to idling in the driveway or at a red light it is horrible!!! The idle is very erratic.
YouTube - Erratic Idling
408
Break down:
- JDM B20A motor
- USDM Transmission
Problem:
408
Throttle Position Sensor.
i had erratic idling for 18 months and i just could not figure it out. eventually i thought to change the tp sensor, and it worked.
try unplugging the tp sensor while its idling erratically, when i did this what happend for me was the car held idle (no longer erratic) but it was holding it high around 2k rpm.
so i bought a new one and voila!
408Honda
Feb 16, 2010 09:00 AM
