Fully Built B18A1
Old Aug 14, 2010 | 01:16 PM
justhatched231's Avatar
Default Fully Built B18A1
This motor was built professionally by C-Tech Performance in Wyoming,MI ($6,500 in labor). Motor has 20,000 miles on it currently.
The Head:
(Fully cleaned, gasket match ported intake, gasket match ported
exhaust/polished, polished combustion chambers, gasket surfaces cleaned)
Super tech valves, springs, retainers & valve seals
valve clearances checked
head milled .030
5 angle valve job
Crower Stage 2 403 camshafts
Crower polished camgears
ARP Head & Main studs
Gates Racing timing and supertine belt
Skunk2 intake manifold
All Cometic Gaskets including Headgasket in the head
The Block:
Mahle 10.5 Pistons, rings, & pins
Bored over .25 MM
BILLET CROWERODS ACURA INTEGRA 1.8
OEM Oil Pan (MOROSO not includled)
ACL Race main, rod and thrust bearings
Cometic Full Gasket kit C4388 & Head gasket C4238-030
ARP rod bolts
Fresh Hone
Block Completely hand cleaned and Black silcone coated
Oil changed every 3K with Royal Purple Oil and Fram or K&N Filters
Engine Dress Up:
Skunk2 oil cap,
B20 Silver Powdercoated valvecover
Aftermarket crank pulley, §§§§§, alternator, fuel rail and injectors not includled. This is strictly a short block.
I am sure I am missing some things.
I will trade for a B18 Vtec head that is fully built or OEM plus cash.
Asking $1750 OBO
I have photos of the complete build if need be.
justhatched231
Dec 2, 2010 04:28 PM
justhatched231
Oct 21, 2010 06:11 PM
justhatched231
Oct 17, 2010 05:49 PM
hanginbyaccord
Mar 7, 2010 10:20 AM
