is it possible to tighten the rear view mirror??
Old Sep 17, 2002 | 02:36 AM
kucherenko's Avatar
Default is it possible to tighten the rear view mirror??
i have a weak *** JL speaker in a compression box with my bass set really low on my deck..and if i put a broadway mirror on it, it will lower itself with each puny punch... does anyone else have a problem with this and could help me out? thanks much appreiciated and sorry if this was not the right place for this post.
Old Sep 17, 2002 | 07:05 AM
99FoxSi's Avatar
Default Re: is it possible to tighten the rear view mirror?? (kucherenko)
Ya, I have the same problem too! Anyone know?
Old Sep 17, 2002 | 07:19 AM
2000GSR's Avatar
Default Re: is it possible to tighten the rear view mirror?? (99FoxSi)
I also got the same problem!!! Mine turns all the way upside down! Any suggestions anybody?!?!
Old Sep 17, 2002 | 09:28 AM
The Auto Toy Store's Avatar
Some mirrors have a set screw located on the back of the mount, if your has the screw tighten it and it will help, but it will also make it more difficult to adjust your mirror. Any weight you add to the mirror will make the problem worse because the mirror is only held in place by friction with the mount.
Old Sep 17, 2002 | 01:15 PM
GSRaCeRbOI's Avatar
i had the same problem.. Imagine w/ 3 12's how bad it gets.. 2 bass hits and the mirror would droop down and be reflecting my crotch Lolz...
anyway I took the mirror off so I could take it apart.. you pop off the cover on the headliner.. and its held on by like 3 screws.. after u have it OFF... pop off the cover behind the mirror (on the part where it pivots).. not you expose the hex screw and a plate and a ball that the mirror pivots on... I put some small pieces of cardboard between the metal plate and the pivot and then I tightened down the screw really tight (careful not to break it)... the mirror is really hard to adjust now.. but I'm the only driver of my car so it doesnt matter.. bass hits and it shakes.. but doesn't droop down like before.. at least not as bad...
///Nick
Audio / Security / Video
Feb 11, 2011 10:08 AM
EJ8_TCAN
May 8, 2007 10:28 AM
sgy
Mar 31, 2007 09:02 AM
S2tripleO
Honda S2000
Jul 16, 2006 11:37 AM
CereaLand
Mar 25, 2003 07:09 PM
