Fuel Help
Old Sep 17, 2002 | 12:22 AM
CivicEK.PDX's Avatar
Default Fuel Help
Ok.....i have a feeling I am running my injectors at the max (how can I find out for sure)? Anyways if I got higher CC injectors can I just plug them in and it will be ok? Would I need to adjust by using a FPR? thanks
Old Sep 17, 2002 | 12:36 AM
riceboy's Avatar
Default Re: Fuel Help (CivicEK.PDX)
It is much easier for people on the board to diagnose the problem if they know the setup that is generating the problem and what steps you have taken toward the resolution.
Old Sep 17, 2002 | 11:54 AM
Default Re: Fuel Help (riceboy)
ok...for this motor:
B16A2 (decked .008" and used middle layer OEM gasket approx: 11:1 CR)
Ti Retainers
ITR/ Si injectors
ITR Valvetrain (valves, springs, IT P&P)
ITR Intake Manifold & Throttlebody
ITR Cams & Skunk2 Cam gears
ITR Fuel Pump (Came out of a flooded car)
ITR FPR
CTR ECU
JDM ITR 4-1
2.5" Crasound Cat
Modified B-Pipe (cut the first bottleneck out)
Now I am gonna swicth out the ITR puel pump for a GSR (do they flow the same?). Also should I stick back on the B16A2 FPR?
Thanks
Old Sep 18, 2002 | 11:14 PM
riceboy's Avatar
If your running stock injectors (since you didn't mention what injectors you're using, I'll assume that they are stock) then you probably are not close to maxing them out on that setup as it is right now, and BTW, the largest injector that will work on a stock ECU is 310cc.
Old Sep 19, 2002 | 01:27 AM
do you know the flow of different fuel pumps (IE: b16a2, b18c5, b18c1, d16y7, etc.)?
Old Sep 19, 2002 | 11:03 PM
riceboy's Avatar
Don't know the fow rates, sorry, but I do know that Honda does not make different pumps for different motors, they have a handfull of different pumps that they design for the car, the stock Integra pump flows more than the stock GS-T Eclipse pump, I do know that.
court76wi
May 3, 2009 11:40 AM
92integraVTECgsr
11
May 29, 2008 04:28 AM
92integraVTECgsr
Sep 5, 2005 07:50 PM
p-boy
Jul 25, 2002 04:11 AM
austrian type-R
Dec 23, 2001 07:07 AM
