Avgas on a stock motor??
Will running avgas on a stock B16a with I/H/E make a power difference??? The compression for a stock motor is pretty high. A lot of locals say it will only make a difference if I up my compression but these are V8 heads....
I've done a search but I was after drag racers input. What would I do with the timing if I run avgas???
TIA
TIA
I wouldn't do it. If i'm not mistaken avgas is a leaded gas which would not go good with stock valve seals. All I know is when I used to fuel planes it was blue
Yep you will lose power unless you are already detonating, one thing you could do is advance the ignition timing when racing! You can use av gas for in small amounts it doesn't ruin your o2 sensors straight away I think you get about 5 hours use before you clog the o2 sensors. Check out mobil race gas if you can it only has .58 mg of lead per litre most av gas has about 5.8mg/litre
I would not do it, you will not benefit from it... esp. on a stock motor.
Now if your timing is crazy aggressive and your running like 12:1 compression or more... it would be a different story.
