F/S K20/K24 Fully Built Turbo Motor!!
Whats good? Im parting out my K20/K24 Turbo Build. There is nothing wrong with the car or its parts. All parts were purchased new. It was meant to be a track car so it was never driven on the street, the only type of action this car has seen is the DYNO. The motor comes complete with harness, intake and all sensors!!
Will Trade for: 92-95 EG Hatch: Seats MINT Carbon Fenders, Mint Carbon Hood, Mint Carbon Trunk, Mint Carbon Doors, SSR Headers, AFI Mani, 36mm HUBS. PM ME with Trades and pictures!!
$5800
Price lowered!!!! $5500
$4800 !!!With out Harness, Intake,
Head K20a2:
Supertech Valves with heat coating
Supertech Duel Springs and Retainer (springs rated for 40PSI+ of Boost)
Supertech Valve Steam Seals
Supertech Up graded valve locks
Skunk2 all motor cams
Block K24:
Z10 AEBS Sleeves (Same sleeves as Miller from NRG) Rated for 55PSI+
Z10 Block O-ring
Bored and Honed to 88MM
Manley Turbo Tuff Rods 1000HP Rated
CP 9:0 88mm Pistons W/ Up Graded Wrist Pins
Hytec modified Type S oil pump
APR Head Studs
ACL Race Bearings and Thrush washer
FG2 Aluminum Oil pan W/ -10an for oil return
New OEM Crank
New OEM Chain
New OEM Chain Guides
New OEM Tensioner
Motor Comes with:
Xcessive Manifold w/ 88mm Throttle body w/ all sensors
K20 Harness and charge harness
Starter
Alternator
waterpump
all pulleys and Dayco Belt
All gaskets and sensors
$5800
Head K20a2:
Block K24:
Z10 Block O-ring
APR Head Studs
New OEM Crank
New OEM Chain
New OEM Tensioner
Motor Comes with:
Starter
Alternator
waterpump
