b series tranny question
Old Aug 12, 2010 | 08:11 PM
germanegturbo's Avatar
Default b series tranny question
so we recently went 9.85 on a stock used gsr transmission and after about a good 80 dyno puls and 40 Ish passes 4th gear famoulsy let go..we are rebuilding again with stock gear set for now but im just wondering from personal experieces what you guys do to keep trannys together in the 700to 850 hp range
thank you
mike from germany
Old Aug 12, 2010 | 10:36 PM
str8JDMteggy's Avatar
Default Re: b series tranny question
You really just need a gear set for that kinda power. You can cuff the stock gears to help though
Old Aug 12, 2010 | 10:58 PM
lunatics209's Avatar
It's funny you're asking for advice when you're the one getting tons of passes with a stock tranny.... Alot of guys making 800+ can't even get off the dyno or make one pass with a stock trans.
Old Aug 13, 2010 | 05:48 AM
tuhboek's Avatar
If you have had that much luck on a stock gear set, I would heat treat your gears when you rebuild and replacee 5th gear with a cuff and see how that holds up for ya. Thats what I may end up doing since I dont have the $ for a dog box.
Old Aug 13, 2010 | 02:32 PM
Blown90hatcH's Avatar
https://honda-tech.com/forums/drag-racing-36/racerstev-treated-gears-check-2070658/
https://honda-tech.com/forums/drag-racing-36/race-transmissions-1692990/
I had good success with the RacerStev treatment.
Old Aug 13, 2010 | 04:32 PM
boostedcivicsir's Avatar
Mr. Badwrench
racer stev treated my gears, and all my 4th gear failures have been 2 treated, 1 non, NEW gears from honda. (im not blaming him at all. he has treated many sets for me as well as friends.) i have been using the same 1-2-3 and fd since 01 (knocks on wood)
got a used b16 4th gear for this time around, and trying some things in the oil. hit up the guys from dynamic performance. allan and rolondo. they are pretty good with helping on stock trannies.
Old Aug 13, 2010 | 05:11 PM
3minburnout's Avatar
Could also hit up godfather of boost on here he knows a thing or two about stock trannys ; )
Old Aug 13, 2010 | 06:20 PM
ALL IMPORT's Avatar
its the heat & load that will let them break no treatment will help that.
it is what it is.
Old Aug 13, 2010 | 06:56 PM
heavy duty's Avatar
I think a lot has to do with what gear racerstev gets (new oem vs used 70k mile old) to treat I like his work alot had a fd done run it for one year street and strip at around 550 and it did fine. If you send him a set i thing the used ones do better. They have been heat cycled a few times and i think it helps.
JUST MY .02
Old Aug 13, 2010 | 09:41 PM
Zer0_SpeedWorks's Avatar
also dynamic performance is having ton of luck with their stock trannies... I think you should consult them too...
what about liberty's faceplate service for oem gears?
Old Aug 13, 2010 | 09:47 PM
MFactory's Avatar
All faceplating does is change the engagement type from synchronous to dog, doesn't improve the strength or durability of the gears.
If anyone is interested in trying our Wide Peening + Ti-Moly Impregnation treatment on their oem gears, let me know. We do this on all the road/race and touring car transmissions we build that need to stick to oem gears, and helps increase impact resistance and decrease friction/heat.
MurkyRiversEK
Transmission & Drivetrain
19
Aug 14, 2012 12:45 PM
serg472
Dec 6, 2010 06:54 PM
LS-VTEC-TURBO-EF9
Mar 16, 2009 04:17 PM
dcloo
Sep 28, 2007 05:04 AM
silverboost
Apr 13, 2007 10:06 AM
