Line lock vs. staging brake
A line loc is useless on a fwd. U have to roll in ....hit the brake.... hit the button... let go of the brake... hit the gas ...let go of the clutch and the button. Use the staging brake. Every stick shift race car should have one. I just installed a kens kustom brake in my buddies mustang. With the stage brake u don't have to fumble your feet around while staging.
only reason i dont want the kens kustom is it takes away your rear brakes from the pedal right? that would make me not want to ever drive my car on the street...
It probably has to do with how much time it takes for the staging brake to fully release the brakes vs the line lock doing it instantly or at a faster rate. Also reflex wise it's probably easier to push or release a button compared to pulling or releasing a lever. Only thing I can think of.
Alan Johnson uses a staging brake and he is a really good leaver. I think most of the guys in pro stock use a line-loc because they like to hold the car in gear in every gear. If you watch the in car on most the guys they hold the lever in place. They don't take their hand off until it's time to push to throw the chutes.
I think in a FWD car the staging brake just works easier for what we are trying to do. It makes pre loading way easier!
If your worried about not having the rear breaks with a staging brake, use a CNC staging brake (the one without the resovor). I bought one because I was worried about the same thing. The CNC staging brake installs inline to the rear breaks. When you dont have the handle pulled the fluid will flow like the hand brake is not there. So on the street and the end of the track you will still have rear breaks.
http://www.summitracing.com/parts/SUM-760002/ this is what i used. two on the rear cause they can't be used in diagnol braking systems
http://www.cncbrakes.com/hsb.asp?grp...412&subseries=
What nobodys mentioned is why not staging brake on the fronts? I've been thinking about that for a while. Seems like it would hold better. Use the E-brake to burnout, and CNC staging brake on the fronts for staging. More than one occasion I've deep staged because I had to little e-brake hold going on with the rears. A few VERY close red-lights were also the result of the deep stage. Maybe I need to "man-up" and pull it harder (that's what she said).
Now, I dont see why setting them for the fronts would hurt or cause problems, except preloading the tires. Youll be able to preload everything up to the outside of the axles. The breaks will keep you from preloading the tires. And from what I understand you want to preload the entire drivetrain including the tires. But correct me if Im wrong.
good point, never thought about it. Your are technically preloading the rim against the tire as well. I gotta think about this for a second...(old guy stuff.)
Ok so lets say you have line locks and you are using 2 step on a button. So you get to the line stomp on the breaks. Activate line locks and two step, stomp on the clutch and gas. Light turns green and release the line locks & 2 step and clutch all at the same time?? This is were im loss becasue i dont see how this is preloding the tranny if you have the clutch in.
line lock the rears....pre stage...line loc, then stage....it will drag the rears and preload the driveline...really the simplest way is just to use a staging brake or the good old fashioned e brake.
