Help..h23 engine swap wont start
Old Aug 12, 2010 | 07:22 PM
92sully's Avatar
Default Help..h23 engine swap wont start
Hi i have a 92 that i swapped the old motor for a h23 i put it in and tried to start it and it just wont turn over...i bought a new distributor and ecu for the engine...im looking at the main rely...my biggest question is i get no spark at all to the plugs...its a brand new distributor and still no spark. what else should i do or look at? i need help
Old Aug 12, 2010 | 08:30 PM
latinman07's Avatar
Default Re: Help..h23 engine swap wont start
OK i had the same problem first you should check the fuse box inside car cause i had one blown an my car did not want to throw electricity or check the main relay too
Old Aug 12, 2010 | 08:34 PM
CRX Si69's Avatar
does anything at all happen when you turn on the ignition? does the dash turn on?
Old Aug 13, 2010 | 12:19 PM
92sully's Avatar
Yeah n the check engine light came on. It sounds like it wants to turn I'm just not getting spark at all
reddcoupe
Jun 12, 2012 04:48 AM
TooGz88
Jan 11, 2008 08:06 PM
sohc90rex
16
Dec 21, 2005 09:20 PM
BLuDoHcReX
11
Feb 5, 2003 05:32 PM
No More Civic
10
Aug 27, 2002 09:35 AM
