magnus intake manifold
Old Aug 12, 2010 | 06:29 PM
85mmek9's Avatar
Default magnus intake manifold
I have had a magnus intake mani since they first came out, my question is had anyone actually tested or have done any comparison with this manifold? Since im out for the rest of the season im trying to get all my **** together so I can take it down to tony. If I should buy another manifold I will, but not really trying to spend $1500 or so.
Your imput would be appreciated.
Old Aug 12, 2010 | 07:00 PM
josh green's Avatar
Default Re: magnus intake manifold
I guess the big question is what are you trying to do with the motor?
Old Aug 12, 2010 | 07:03 PM
boostedeg302's Avatar
Tell us your setup so someone can further help you. Im guessing its a high revving, setup but then again, not sure till you let us know.
Old Aug 12, 2010 | 07:15 PM
BMCRace's Avatar
Your manifold could very well be the winning ticket for your setup.
A lot of people want to much of a manifold not understanding that it could actually hurt them. Each manifold with different specs (primary length, plenum volume, etc) is most efficient for a certain setup.
Example:
If you go running to big of a plenum with to little of power you would actually be at a lower efficiency than if you were to run a smaller plenum (thus giving you lower hp if other variables such as temp, and boost were the same).
Old Aug 12, 2010 | 08:44 PM
85mmek9's Avatar
yes high rpm motor. little break down.
84.5mm b series
10.1 compression
s372r 1.25ar
redline 10k-10.5k.
etc. etc...
850-950hp.
of course im looking for mid to top end power, or just something that is going to work right. I dunno if this one is or not because I have not had the best of luck this year, but making sure next year **** is right. That is why I have made this thread.
Old Aug 13, 2010 | 06:16 AM
Turbo-charged's Avatar
check out the bmc manifolds, its the nicest stuff out there right now IMO. the plenum on the magnus manifold is pretty small. we used a magnus manifold on an h22....an edelbrock manifold sitting next to it actually made the magnus look small. unfortunatly did not do any kind of before and after tests or anything
Old Aug 13, 2010 | 06:26 AM
kcevo's Avatar
We are running the race series and a 75mm Throttle Body and are still making power to 10.8k on the dyno. This was at 31.5psi, would have turned it up more but we were out of fuel running e98.
Setup is identical to yours besides bore size.
Old Aug 13, 2010 | 07:13 AM
tony1's Avatar
Weird, the Magnus B series stuff i've seen (had one right next to an Edelbrock) is much bigger than the Edelbrock as far as the plenum goes.
If you're going to spend big money, i'd get the Kinsler intake. You get to choose runner length, runner diameter, degreee of taper, angle of port entry, plenum volume, number of injectors, CNC matched to your port dimension, etc. And it's half magnesium and half aluminum, so it's pretty light for what it is.
Old Aug 13, 2010 | 07:36 AM
really? i havnt used a b series magnus. when we had the h series one we were shocked how small it was, even though it hit the rear engine mount
im sure the kinsler is badass, but it hasnt grown on me cosmetically yet lol. can you get it flanged for something other than the fugly q45 throttlebody? im a weirdo i know haha
Old Aug 13, 2010 | 07:47 AM
tony1's Avatar
Can be flanged for anything you want. Mine is for a 4 bolt mustang pattern, with a 90mm Wilson TB.
Old Aug 13, 2010 | 09:36 AM
k24 ek's Avatar
thats weird because my brother has one on his H22 and it's bigger than an Edelbrock
Old Aug 13, 2010 | 11:01 AM
kcevo's Avatar
The one we have is much larger plenum wise than the edlebrock.
Old Aug 13, 2010 | 11:04 AM
85mmek9's Avatar
that kinsler is badass but out of my price range. Do you think it would be worth my while to change, to say the BMC? It seems I have been a guinea pig on all kinds of **** and just want to get this to work right so we can get the most out of it. But if its not going to make a diff to change unless I have to buy a 2-3k mani ill stick with what I have.
Old Aug 13, 2010 | 01:07 PM
Clayton's Avatar
H-T Administrator
25 Year Member
As far as guinea pig, you would not be the first to use a Magnus manifold. I'd suggest calling or emailing them to ask them your questions first hand
Old Aug 13, 2010 | 02:34 PM
ALL IMPORT's Avatar
BMC ALL DAY!!!!!
Old Aug 13, 2010 | 02:43 PM
hello1320's Avatar
Call cft......they have a good relationship with Magnus and have uses the manifolds on all of their cars
Old Aug 13, 2010 | 03:46 PM
redboost10's Avatar
we were using a magnus on my 84mm gsr, s372r setup and made 831whp at 36 psi on a mustang dyno, we were pretty happy with it.
Old Aug 13, 2010 | 03:55 PM
MrParks's Avatar
bmcrace.com proven.
Old Aug 13, 2010 | 08:50 PM
SlowReaction's Avatar
Originally Posted by MrParks
bmcrace.com proven.
Nothing against BMC, but who was it proven by?
Old Aug 16, 2010 | 12:44 PM
GT30EK's Avatar
I just made 810whp at 33psi on a S366 with a magnus manifold.
Old Aug 17, 2010 | 05:00 PM
xenocron's Avatar
id like to know as well...because i've missed any results, i've only seen pretty pictures
Old Aug 17, 2010 | 06:45 PM
BMCRace's Avatar
Wanna argue the numbers?
Hit up the mod, Antilag , its his car
Old Aug 17, 2010 | 06:47 PM
tony1's Avatar
Not much of a powerband...
Old Aug 17, 2010 | 06:55 PM
dankeg's Avatar
powerband>peak
Old Aug 17, 2010 | 11:54 PM
ScorpioMk's Avatar
whats the motor setup/turbo etc. peak trq at 9k?
