innovate wideband LC1 and o2 simulation?
im following the directions in the manual here for simulation of the analog o2, i have the yellow analog output 1 wired to the red/white o2 sensor signal wire going into the ECU, however...it doesnt explain the o2 heater wiring, and i find it hard to believe thats not gona throw a code if you leave it unplugged.
c. Vehicle has a 3-wire sensor:
Typically the 3 wires are: heater power, Ground, and sensor element connection.Generally they have 1 black wire and 2 white wires. Connect the black wire from the EFI computer to analog output 1 of the meter. Leave the other wires unconnected but make sure they cannot contact any metal parts or see above. If the wiring colors are different, then heater power can simply be determined by measuring the voltage on the wires when the engine is running. The wire showing 12V or more is the heater power. The sensor element connection voltage fluctuates around 0.45V when the car is warmed up. Wire analog output 1 directly to this wire. The Ground connection has low resistance to chassis ground (less than 1 Ohm). Measure while the engine is off.
d. Vehicle has a 4-wire sensor
Typically the 4 wires are: heater power, heater ground, sensor ground, and sensor element connection. Proceed as for the 3-wire sensor.
Iron_Forrix
Jan 11, 2007 06:57 PM
HXMan
Apr 26, 2002 08:13 AM
connect, connection, heater, honda, hondatech, innovate, innovative, lc1, pc, program, simulate, simulation, simulator, wideband, wires
