Replacing wheel studs - How To?
Old Sep 16, 2002 | 10:39 PM
dynamo's Avatar
Default Replacing wheel studs - How To?
The thread on a couple of my wheel wheel studs is 'rounded off' and I am having a hard time putting the lugnuts on. I was thinking of replacing them with stock ones, but am not sure on how to do it.
I have taken the rear wheel/hub assembly in the past, and had taken apart most of the front ones. I don't know how to take the studs out, or put in new ones. Could someone please give me some pointers on how to get this done?
Old Sep 18, 2002 | 06:59 AM
TimoneX's Avatar
New User
Default Re: Replacing wheel studs - How To? (dynamo)
Well once you have the disc off the car it's fairly simple. With the old studs, I'd just get an old lug, put it on the top of the stud in question(assuming it's still somewhat intact) then pound it out the back. With the new studs you naturally must be a bit more gentle. I like to put these in as far as they'll go then put several washers on the stud. Put a lug on there, oil the whole mess up and tighten the lug. This will pull the stud into place without any damage.
Old Sep 18, 2002 | 12:10 PM
Merlin1068's Avatar
He is Correct, Take a BFH (Big Fu#$ing Hammer) whack the old ones out they are just pressed in.
Yes be more gentle on re installing the new ones. Washers help, or use an old spare rim, put all the new lugs in and tap them a little to get started then put it on the old rim and tighten the whole mess up.
Poof you are done.
This Aint Yo Momma's Honda
Old Sep 18, 2002 | 06:33 PM
ScrapinSi's Avatar
Default Re: Replacing wheel studs - How To? (Merlin1068)
Or use Acorn lugs and a deep socket... thats what i do...
Old Sep 18, 2002 | 08:28 PM
b18c1civic95's Avatar
Default Re: Replacing wheel studs - How To? (ScrapinSi)
yeah then get really really angry when u find out that its stripped out on the threads that go into the hub. i am waiting for two new hubs because im gay and dont know how to torque bolts when i put on my lugs
Old Sep 18, 2002 | 09:22 PM
TimoneX's Avatar
New User
Default Re: Replacing wheel studs - How To? (b18c1civic95)
I fail to see what your sexual preference has to do with it. Don't you use a torque wrench? I think the #1 mistake inexperienced mechanics make is thinking everything has to be cranked on, till it can't crank no more.
Old Sep 18, 2002 | 10:11 PM
rotten's Avatar
Dude,
The hubs are not threaded, the studs are pressed in. I am not sure what the hell you are talking about.
Old Sep 18, 2002 | 11:21 PM
TimoneX's Avatar
New User
Default Re: Replacing wheel studs - How To? (rotten)
I think he's saying he destroyed the splines that hold the studs in place...if I'm understanding correctly. I'd think that would take a tremendous amount of force and the stud would break long before that happened though.
Old Sep 19, 2002 | 02:51 PM
performula's Avatar
Default Re: Replacing wheel studs - How To? (TimoneX)
WHOA...
How about start from just the wheel being off?
What are the washers for? How are regular washers going to keep the wheel stud from spinning, when tightening/loosening lug?
Old Sep 19, 2002 | 02:58 PM
dynamo's Avatar
Default Re: Replacing wheel studs - How To? (performula)
Yeah, I don't understand that part either.
Also, do the instructions above apply to an EK civic (2000)?
Old Sep 19, 2002 | 03:44 PM
TimoneX's Avatar
New User
You put several washers on and oil them up before you tighten a lug on there. Then when you tighten the lug it pulls the stud into place on the hub. It's a very old trick, often used to remove bolts with a broken head and one end protruding.
Old Sep 19, 2002 | 07:45 PM
dynamo's Avatar
I still don't understand how putting washers on makes it easier on the stud?
Old Sep 19, 2002 | 08:05 PM
TimoneX's Avatar
New User
If you put a lug on there and crank away, chances are the stud will go on anyway. It'll require more elbow grease and whatever is between the lug and wheel hub(if anything) will not like your attitude. Just makes it a bit easier.
Old Sep 20, 2002 | 01:15 AM
BrandonClaps's Avatar
New User
Default Re: Replacing wheel studs - How To? (siblue-sol)
u just hammer at the stud and it will push out.......
the reason you put washers on it, is most likely the lug nut will bottom out before it gets to the Hub, so putting washers on it will bring it out giving the lug more room to tighten and press the stud into place
Old Sep 20, 2002 | 02:02 AM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
What if you just beat the new studs into place with a hammer?
Old Sep 20, 2002 | 11:15 AM
dynamo's Avatar
Default Re: Replacing wheel studs - How To? (ActiveAero Ninja Edition)
They will probably get damaged.
Thanks for the help guys!
Old Sep 20, 2002 | 11:37 AM
New User
it is impossible to "beat" them into place....
Toy Civic
Jun 6, 2008 01:06 PM
Mikey3000
Jan 12, 2006 07:05 AM
mingbling
Jul 27, 2004 09:05 PM
deez nuts
Jun 10, 2004 10:39 PM
Ninjaboi_on_X
Mar 16, 2003 07:14 PM
